PUSH Industries : Elevensix Shock
2/24/2015 : sicklines
, PUSH Industries : Elevensix Shock
PUSH Industries has a great reputation when it comes to improving suspesnion components. They’ve gone the extra mile now and have come out with a new rear shock of their own called the Elevensix.  Learn more about this Colorado manufactured shock inside.
  • MSRP $1,200
  • 100% Manufactured in Colorado at PUSH from the finest domestically sourced raw material.
  • Each unit is hand assembled, vacuum bled, and dyno tested. Built custom to rider specification based on rider weight, riding style, and frame application.
  • Patent Pending Dual Overhead Valve design offers two completely decoupled ride characteristics that can be toggled between on-the-fly. For the first time riders can have ultra plush and ultra firm suspension characteristics without compromise.
  • Tool free external adjustments for Low Speed Rebound, Low Speed Compression, and High Speed Compression.
  • Parabolic Low Speed Needle design for both compression and rebound eliminates the “gap” found in production MTB shock external adjustment.
  • Exclusive HyperCo Ultra Light Suspension Spring available in 25lb/in increments. Made from High Tensile spring alloy and featuring Optimum Body Diameter technology eliminating spring deflection and body wear.
  • Next generation Digressive Damping characteristic from compression valves provides incredible traction and control while allowing for through travel on square impacts.
  • High Volume Oil and Nitrogen Reservoir for fade-free performance.
  • Built using premium Maxima rear shock fluids.
  • Exclusive 360 degree spring capture and bump stop cup eliminates extrusion of bumper under extreme bottoming loads and ensures proper spring alignment.
Learn more at http://www.pushindustries.com/pages/elevensix
