RockShox Bluto Fatbike Suspension Fork 2014
4/10/2014 : sicklines
, RockShox Bluto Fatbike Suspension Fork 2014
RockShox has a new Fatbike specific fork called the BLUTO.  Details inside from RockShox.
You’ve probably observed more and more riders are on bikes that look “different” on your trails. Bikes that have wheels and tires of gigantic proportion – and we’re not talking about 29ers here. The thing is, even though fat bikes were first created to float on top of snow and sand, they’re just too damn fun not to ride on dirt. So how do you amplify your fat bike adventures even further?
With a supercharged, ultra efficient, first of its kind fat suspension fork called BLUTO. We started with the features you’ve come to love from RockShox: Rapid Recovery rebound, Fast Black aluminum upper tubes, the infinitely tunable Solo
Air spring, stout 15mm Maxle Lite, remote or crown adjustable damper, and tapered steerer tube. Then, the chassis got the fat treatment by reengineering it to meet the unique needs of fat tires and wheels. Everything from crown, to arch, to axle has been optimized to tackle the increased torsional loads of its wide stance.
With more traction and control than ever before, you’ll never be happier
you went fat.
Available: June 2014 , 2014
Specs Bluto
Model RL
  • Wheel Size 26”
  • Travel (mm) 80/100/120mm
  • Steerer Tapered
  • Offset 51mm
  • Axle 15×150 Maxle Lite
  • Damper Adjust
  • Crown or Remote (PushLoc)
  • compression to lockout,
  • rebound
  • Spring Solo Air
  • Tire clearance 4.8” max.
  • Color Black, White (OE only), Diffusion
  • Black (OE only)
  • Target Weight 1796g (3.96 lb)
  • MSRP Crown/Remote $643/$711- 572€/632€
  • RockShox Bottomless Tokens
THAT BOTTOMLESS FEELING
• Easily tune your air volume in RS-1, Reba, SID, and Revelation
• Tokens thread in to topcaps just like they do in PIKE
• Black tokens designed to work in 32mm upper tubes
