2014 Troy Lee Designs T-Bone Knee Pads, Semenuk Knee Pads, Panic Knee Guard
3/3/2014 : sicklines
, 2014 Troy Lee Designs T-Bone Knee Pads, Semenuk Knee Pads, Panic Knee Guard
For 2014, Troy Lee Designs has redesigned the T-Bone knee pad. They’ve made it more pliable, lighter, and refined it quite a bit. Check it out and more inside.
In comparison to the previous generation of T-Bone’s, the new pads are significantly different. They’re easier to pedal in and are less restrictive. The padding is not as hard in comparison and the weight comparison is quite significant when you hold both in your hands.
Old T-Bone (left) New T-Bone (right)
New T-Bone (left) Old T-Bone(right)
T-Bone Details:
  • Molded EVA outer knee shell with ballistic nylon cover
  • Knee cup consists of a combination stack of memory foam for secure performance fit
  • The knee sleeve is ergonomically contoured with two elastic velcro closures and internal silicone grippers
  • Lightweight and low profile, this knee guard can be worn under your pants or with shorts for any riding adventure
  • 3 sizes
  • $68
You can see additional comparison shots in the gallery as well.
Gallery
If you’re after a Semenuk inspired knee pad, TLD has answered your call for 2014 with the Semenuk Knee Guards. They’re slim and tapered to help fit under jeans easier.
  • Brandon Semenuk inspired design and graphics
  • Abrasion resistant nylon over CE-1621-1 certified impact liner padding to absorb big hits
  • Molded and formed EVA padding in key wear and abrasion zones
  • Airprene & neoprene for improved ventilation and ultra contouring fit
  • Anatomically built in pre curve for optimal riding position, fit and comfort
  • Slim and tapered design to fit under pants and still provide excellent protection
  • Fully adjustable thigh and mid calf elastic straps to keep pad secure on any terrain
  • Available in 3 sizes
  • $98
Panic Knee Guards
  • Extra long lower EVA padding provides ample protection in shin areas
  • Airprene, breathable neoprene for improved ventilation and an ultra contouring fit
  • Built in pre curve for optimal riding position, fit and comfort
  • Slim and tapered design to fit under pants while still providing excellent protection
  • 3 Sizes
  • $112
E-Lite Guards (slip-on elbow)
The E-Lite guards are ultra thin slip-on elbow guards that would work well for enduro/trail/xc riders looking for a little bit of joint protection.
  • Ergonomically designed ultra thin performance slip-on elbow guard
  • Lightweight lycra sleeve constructed with internal silicone arm grippers
  • Molded energy absorbing co-polymer impact pad with added internal memory foam panels
  • Light streamline design for a minimal yet effective approach to arm protection
  • 3 sizes
  • $35
Be sure to check out our post on some of the 2014 TLD clothing items.
2014 TLD Catalog
Stay tuned for more details on the 2014 Troy Lee Designs gear and visit www.troyleedesigns.com to see more
