2014 Specialized Enduro Expert Evo – Ohlins TTX
7/15/2013 : sicklines
Learn more about the 2014 Specialized Enduro Expert Evo inside. Like the high-end Demo model offerings, the 26″ Enduro Expert Evo also gets the Ohlins TTX22M shock as well. In addition to the new shock, the Enduro Expert Evo also get’s SRAM’s new X01 11 speed drivetrain that is pretty awesome.
, 2014 Specialized Enduro Expert Evo – Ohlins TTX
Enduro Expert Evo
Features:
The fully manipulated M5 alloy FSR frame with ORE tubing is the centerpiece of this incredibly versatile 180mm-travel design; featuring sealed cartridge bearing pivots, 142+ dropouts, ISCG ’05 chainguide mounts, and a replaceable derailleur hanger.
In a groundbreaking partnership, Specialized and Öhlins suspension have teamed up to develop the best performing bike and shock combination. The TTX22M shock uses Öhlins patented twin-tube design to separate compression from rebound.  Spring rates are also available in ~25lb increments for the Ohlins springs.  This shock is currently exclusive to Specialized and you can also see it on board select 2014 Demo 8 bikes as well.
Ohlins shock
FOX 36 Van RC2 Kashima 180mm coil-sprung fork with 20mm thru-axle, tapered alloy steerer, and preload and rebound adjust for All-Mountain shredding and aggressive descending
SRAM X01 - 1x11speed drivetrain
  • New SRAM SRAM X01 Type 2, 11-speed, medium cage rear derailleur
  • Custom SRAM S-2200 carbon All-Mountain crankset with 11-speed gearing is built for strong, lightweight performance
  • Roval Traverse All-Mountain wheelset with DT Swiss spokes, 20mm thru-axle, and a 142+ rear hub spacing for durable, lightweight, and tubeless-ready performance
  • Specialized Butcher SX 2.3″ dual compound front tire for premium traction on challenging terrain
  • All-new, hidden Specialized Command Post IR uses a remote lever to adjust saddle height on-the-fly to maximize climbing and descending performance
Specialized continues to push their build specifications to suit various rider sizes.  If you take note of the spring rate , stems, dropper post seatpost range, and grips across their lineup you’ll notice they try to tailor fit the bike to better fit riders of various sizes.  This type of detail is something more companies can do as it helps the consumer enjoy their bike setup much more out of the box.
Enduro Expert Evo front
Specifications
  • FRAME M5 aluminum, EVO geometry, tapered headtube, PF30 BB, ISCG ’05 mount, internal Command Post IR routing, 142+ dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 180mm travel
  • REAR SHOCK Custom Ohlins TTX22M, coil over w/ piggy back, spherical bearing mount, high/low speed comp, reb adj., 8.75×2.5″, S: 76x434lb, M: 84x479lb, L: 92x525lb
  • FORK FOX 36 Van RC2, Kashima coating, coil spring, tapered alloy steerer, high/low speed comp and reb adj., 20mm thru-axle, 180mm travel
  • HEADSET 1-1/8 and 1-1/2″ threadless, Campy style upper with 1-1/2″ lower, cartridge bearings
  • STEM Specialized P.Series MTB, forged alloy, 4-bolt, 40mm length, 31.8mm clamp
  • HANDLEBARS Specialized Demo, low-rise, 7050 alloy, 780mm wide, 8-degree backsweep, 6-degree upsweep, 31.8mm
  • GRIPS Specialized Sip Grip, light lock-on, half-waffle aramid-infused, S/M: regular, Others: XL thickness
  • FRONT BRAKE Custom Avid Elixir 7 Trail, 4-piston caliper, steel backed metallic pad, 200mm rotor
  • REAR BRAKE Custom Avid Elixir 7 Trail, 4-piston caliper, steel backed metallic pad, 180mm rotor
  • BRAKE LEVERS Custom Avid Elixir 7 Trail, hydraulic disc, tool-less reach adj.
  • REAR DERAILLEUR SRAM X01 Type 2, 11-speed, mid cage
  • SHIFT LEVERS SRAM X01, 11-speed, trigger
  • CASSETTE SRAM X01, 11-speed, 10-42
  • CHAIN SRAM X01, 11-speed, hollow plates/pins, PowerLink
  • CRANKSET Custom SRAM carbon S-2200, 34T XX1 style single ring, PF30 spindle, removable spider, S: 170mm, Others: 175mm
  • CHAINRING – 34T
  • BOTTOM BRACKET SRAM PF30, OS press-in bearings, sealed cartridge
  • RIMS Roval DH 26, alloy disc, 23mm internal width, 32h
  • FRONT HUB Specialized Hi Lo disc, sealed cartridge bearings, 20mm thru-axle, 32h
  • REAR HUB Custom DT Swiss, Star Ratchet, XX1 driver body, 142mm, 32h
  • SPOKES DT Industry Stainless, 3X front/rear 2.0mm
  • FRONT TIRE Specialized Butcher SX, 2Bliss Ready, 26×2.3″, foldable aramid bead, dual-compound, 60TPI
  • REAR TIRE Specialized Butcher SX, 2Bliss Ready, 26×2.3″, foldable aramid bead, dual-compound, 60TPI
  • SADDLE Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
  • SEATPOST Specialized Command Post IR, 3-position, internally routed adjustable height w/ air spring, remote operated, single bolt head, 30.9mm, S:100mm, Others: 125mm travel
  • SEAT Collar – 7050 hard anodized alloy collar, single bolt, 34.9mm
Geometry
Geometry
Pricing
  • $5,800 (USD)
You can see more pictures of the 2014 Specialized Enduro Evo Expert in our gallery.
Stay tuned to see more 2014 Specialized content.
