RockShox sent through some details of a new Pike fork they’ve been developing. Details inside.
Using a 35mm chassis, new crown, 15×100 axle, and tapered steerer. They created a new Charger damper system (bladder charged system).
CHARGER DAMPER
Simply put, the all-new Charger damper we developed for PIKE is the most refined damper RockShox has ever produced. It’s a bladder-charged damper, which means it has consistent performance even during the longest, hardest descents, plus it allows complete control for the trail with open, pedal and lock positions (RCT3 version). A Rapid Recovery rebound circuit completes what many testers have described as the “best RockShox fork ever made.”
INTRODUCING THE ALL-NEW ROCKSHOX PIKE
• Lyrik stiffness at near Revelation weight
• Rider focused features
• The most refined damper
• Asymmetrical Lower leg
• New Maxle lite
• Low friction single seal
• Slotted upper bushings
• Solo air and dual position air
• All wheel sizes available
• 15 x 100 axle only
• Tapered steerer tube only
Two models, RC and RCT3
MODEL: RCT3
WHEEL SIZE: 26”, 27.5”, 29”
WEIGHT*: 26” – 1835g (4.05 lb), 27.5” – 1861g (4.10 lb), 29” – 1876g (4.14 lb)
TRAVEL: 26”/27.5” – 150mm, 160mm; 29” – 140mm, 150mm
STEERER:Tapered only
AXLE: Maxle Lite 15mm
ADJUSTMENTS: External rebound, low speed compression, 3-position compression (Open/Pedal/Lock)
SPRING: Dual Position Air, Solo Air
CROWN: Forged, hollow 7075 Aluminum
LOWER LEGS: Magnesium, disc only
MAXIMUM ROTOR SIZE: 200mm
COLORS: Black, White
MSRP: $980-1085 (878-949€)
Visit sram.com for more details.
