2013 Royal Racing Clothing Lineup
9/17/2012 : sicklines
For 2013, Royal Racing has got an impressive lineup of offerings to pick from. Downhill, freeride, all mountain, xc, and more are easily covered with their 2013 range of products. There are some new women’s offerings as well to consider. Check it out inside.
Royal 2013 Catalog (view PDF)
, 2013 Royal Racing Clothing Lineup
Royal Drift Ride Long Sleeve Shirt and Drift Shorts
Drift Ride – Long Sleeve Jersey
The Drift jersey can match up with our Drift short or you can wear it with any of our shorts, the whole
line is cross merchandised so all styles look great with each other. This is our mid level All Mountain
and trail long sleeve jersey. This year it features a few extra trims that set it apart from the competition.
Wear it. Ride it. Smash it.
Features:
– General Issue Fabric
– Asymmetrical Design
– Screen printed graphics front and rear
– Royal woven flag label
– TPR direct inject detailing on collar
– Heat transfer no scratch inner neck label
– Direct inject TPR detailing on collar
Drift Short
Tough enough for all kinds of all-mountain riding this is’ the go to’ short when planning an epic day in
the dirt.
The Drift short features fully perforated Cordura, designed to keep you cool whilst still being durable.
A great bike park and ‘all mountain’ short. The Drift, like all our 13 collection can be mix and matched
with any jersey from our collection.
Features:
– Sonic perforated 600D Cordura fabric with 2 years of testing gives full ventilation, so no more sweat-
ing before you have even started your ride.
– TPR waist adjusters
– Wicking internal mesh liner
– Internal waterproof back panel – no more wet underwear
– 2 hand pockets, 1 reverse hand pocket and 1 thigh pocket all featuring reverse tape zippers
– Double snap waist closures so only your bike does the drops and not your shorts
Slice Long Sleeve
Slice Long Sleeve Jersey
Casual and technical, the best of both worlds.
Features:
– General Issue Plus fabric
– Moisture wicking quick drying
– Casual fit and feel
– Heat transfer inner neck no scratch label
– Taped for comfort rear neck seam
– Woven flag label
Race Jersey and Race Shorts
Race Jersey
Technically engineered airflow mesh fabric enables superior venting and performance with minimum
drag and ultra lightweight (only 195grams). Is this the most advanced MTB DH race
jersey ever?
Features:
– Air Flow fabric
– Weightless sublimated no fade graphics
– Engineered mesh
– Low profile Leatt compatible neck construction
– Rear neck expanding panel
– Side of body and pit venting panels
– Flat no scratch rear neck label
– Micro Lycra taped stretch cuffs
– Wrap around arm venting
Race Short and Race Jersey
Race Short
Listening to the feedback from Aaron, Niko, Justin and Steve has enabled us to create a non-restric-
tive race short, ultra lightweight (only 485grams) and vented for airflow with minimum drag. The 2013
Race Short is worthy of the world-class riders who have developed it. See it soon on a podium near
you soon!
Features:
– Unique ‘pedal friendly’ tailored fit
– Laser cut ventilated 500D Polyester body fabric
– 4 way stretch flex zones front and rear
– Dual adjustable hook and loop waist adjustment tabs, with soft Hip crush zone
– Full moisture wicking quick dry mesh lining
– Ergonomic cut leg openings
– Laser cut and bonded rear venting
– Lower back/coccyx embossed padded panel
– Dual hollow pop snap waist closure
Gloves
Gloves
Royal Racing has a wide variety of gloves for both men and women. Multiple styles to give different degrees of mobility, venting, and everything between lightweight to heavy duty.
SP 247 Jersey and Shorts
SP 247 Jersey
If it is an all-round, great value gravity jersey you require, the SP247 is just the ticket. Developed in the
saddle by none other than ‘Mr DH’ Steve Peat, we can confidently say the SP line will never let you
down.
Features:
– 100% polyester fabrics
– Low profile Leatt compatible sponge padded neck construction
SP-247 Shorts
The SP247 short is tough enough to perform like full
on downhill race kit and yet light enough to be worn
out on the trails. The SP247 Short offers great fea-
tures at a competitive price point. The SP range has
been designed and developed by Mr. Steve Peat.
Features:
– Unique pedal friendly fit
– 500D Polyester body fabric
– 2 zipped vented hand pockets
– Ratchet adjustable closure waist band
Cutter Hoodie Shirt
Cutter Hoodie Shirt – 24 Months of development!
This is a great piece of gear!
It’s so versatile we weren’t sure where to catalogue it! It’s both a jacket and a shirt!
Casual yet technical, the cutter shirt is great to ride in with its technical apparel performance but
doesn’t look out of place when you just want to chill with your mates. Not only does it have a casual
style and fashion forward look but the Cutter features a water resistant DWR coating so it’s going
to keep the worst of the weather out if you get caught out in a shower. It’s also very lightweight and
packable. Perfect if you’re trail building and riding all in the same day.
Features:
– DWR coated water resistant 100% cotton
– Custom Royal branded snap buttons
– Custom draw cord aglets
– Embroidered Royal and crown logos
– Custom eyelets and suede flags
– All over sublimated plaid
Turbulence Short and Jersey
Turbulence Short
The Turbulence short is light and comfortable for ride long rides on dry days in the dust. But the
Turbulence is more than this, when the weather turns against you we’ve tried to cover every base.
Features like a waterproof back-panel to keep the inner-panel dry and a waterproof audio pocket with
cable routing make this our premium all weather big mountain short.
It’s the detail that makes the difference.
Features:
– 4-Way stretch Bioflex Plus fabric with DWR treatment
– Fully ventilated
– Rear neoprene yolk with TPR detail
– Heat transfer graphics
– Waterproof Audio pocket with I port cable routing
– 2 hand pockets, 2 reverse hand pockets, 1 audio pocket, 2 upper thigh pockets all feature reverse
taped zippers for that clean look
– Removable key and pass lanyard fixed in to pocket with clip
Turbulence Short Sleeve Shirt
The Turbulence jersey sits along side our Turbulence short as our top of our Big Mountain offer. The
short sleeve Turbulence shares all the feature of its long sleeve stable mate.
Features:
– 4 way stretch main body fabric and our square 2 way stretch mesh
– Heat transfers graphics
– Lycra collar
– TPR Royal crown direct inject logo on neck
Womens Concept Short and Jersey
Women’s Concept Short (left outfit)
The Concept is our “all day” women’s trail ride short. It comes complete with a high performance de-
tachable custom Royal short liner and women’s chamois pad. We worked extensively with a group of
women riders to perfect the fit of our women’s range. This short will fit real women, not just fit models!
Features:
– Luminar 4 way stretch fabric and Square 2 way mesh
– Fully ventilated
– Wicking internal mesh liners
– 2 Zipped hand pockets featuring reverse taped zippers for that clean look
– Clip and double snap closure
Women’s Concept Short Sleeve
The Concept Jersey is a no compromise top of the range all mountain jersey, ergonomically crafted
from the finest available 4 way stretch material. The concept has a semi fitted look that is perfect for
blasting the trails. The jersey shares the same features and materials as our men’s Turbulence Jersey,
making it the perfect ’do it all’ jersey.
Features:
– Luminar 4 way stretch main body fabric and our square 2 way stretch mesh
– Strategically placed venting panels
– Lycra collar for comfort
– Direct Inject Royal Crown TPR on neck
Matrix Jacket
Matrix Jacket
The Matrix, our full on breathable waterproof jacket is designed to look good whether you’re in the
saddle or just hanging out, but don’t let this fool you, the Matrix is a full feature storm jacket – 10,000
MVP breathable / waterproof! The hood is big enough to fit over an open face helmet yet has enough
adjustments be perfect for everyday use too.
It’s the detail that counts.
Features:
– Canopy HS 10000 MVP Breathable water proof polyester fabric
– Custom pinstripe design graphics
– TPR moulded Hook and loop cuff adjusters
– Water proof zips
– 3 Secure zipped vented mesh pockets
– Moisture wicking lining
– Toggle adjustable hood and waist
– Reflective heat transfer logos
– Top back mesh vent
– i Port and inner routing
– Casual cycle friendly tailoring
You can see additional 2013 Royal Racing gear in the Eurobike 2012 gallery or visit their website at royalracing.com
