2013 Specialized Status, P3, P26, P.Slope
8/23/2012 : sicklines
Specialized has had good success with the Status that they introduced last year. Last year the Status replaced the Big Hit last year and we’ve seen quite a few in the bike parks under happy riders. For 2013 it still gives aspiring DH riders a good option to consider without breaking the bank.
Check out our video from last year where Buck runs through the details of the Status that still remain the same
, 2013 Specialized Status, P3, P26, P.Slope
Status II complete
Status FSR II  (Black/Charcoal) – 200mm of FSR suspension (S / M / L)
  • FRAME M4 hydroformed tubing, 1.5” forged HT, ISCG mounts, 135mm rear spacing, full-cartridge bearing pivots, 200mmtravel
  • REAR SHOCK Custom Fox VAN RC, coil w/piggy back, compression and rebound adj., 8.75×2.75”, S:400, M:450 L:500
  • FORK RockShox Boxxer RC, alloy steerer, compression and rebound adj., 20mm Maxle DH thru-axle, XS/S: extra-soft spring, M: soft spring, L: medium spring, 200mm travel
  • HEADSET Semi-integrated alloy cups for 1-1/2” HT and 1-1/8” steerer, cartridge bearings
  • STEM Specialized Direct Mount stem, 6061 alloy, 31.8mm clamp, 4-bolt,
  • HANDLEBARS Specialized DH low-rise bar, 6061 alloy, 750mm wide, 8-degree backsweep, 6-degree upsweep, 31.8mm
  • GRIPS Specialized Sip Grip, half-waffle aramid-infused, S/M: Regular, Others: XL thickness
  • FRONT BRAKE Custom Avid Elixir 5 R, metallic pad, HS-1 rotor, 200mm rotor
  • REAR BRAKE Custom Avid Elixir 5 R, metallic pad, HS-1 rotor, 180mm rotor
  • BRAKE LEVERS Custom Avid Elixir 5, hydraulic disc, tool-less reach adj.
  • REAR DERAILLEUR SRAM X7, 9-speed, short cage
  • SHIFT LEVERS SRAM X5, 9-speed, trigger
  • CASSETTE SRAM PG-950, 9-speed, 11-28
  • CHAIN SRAM PG-971, 9-speed
  • CRANKSET Custom SRAM Descendant, GXP, 7050 alloy arms, thin 36T ring, 165mm
  • CHAINRINGS 36T
  • BOTTOM BRACKET SRAM GXP, outboard bearing
  • PEDALS Specialized Bennies, 6061 alloy body, sealed cartridge, 4.5mm removable pins
  • RIMS P-Disc, 32mm, 36h
  • FRONT HUB Specialized Hi Lo disc, laser-etched logo, sealed cartridge bearing, 20mm thru-axle, 36h
  • REAR HUB Specialized Hi Lo disc, sealed cartridge bearing, bolt-on, 36h
  • SPOKES Stainless, 14g
  • FRONT TIRE Specialized Butcher DH, 60 TPI, wire bead, soft dualcompound, 26×2.3”
  • REAR TIRE Specialized Butcher DH, 60 TPI, wire bead, soft dualcompound, 26×2.3”
  • INNER TUBES Standard Schraeder
  • SADDLE Specialized DH, 8mm steel rails
  • SEATPOST Specialized 6061 alloy, two bolt micro adjust, no offset, 30.9mm, 300mm
  • SEAT BINDER Specialized 7050 hard anodized alloy, 34.9mm, single bolt
Status I
Status I (Black / White / Red)
  • FRAME M4 hydroformed tubing, 1.5” forged HT, ISCG mounts, 135mm rear spacing, full-cartridge bearing pivots, 200mm travel
  • REAR SHOCK Custom X-Fusion Vector R, coil over w/piggy back, adj. rebound, 8.5×2.5”, spring rate S: 400, M: 450, L: 500
  • FORK X-Fusion Vengeance, coil spring, tapered alloy steerer, reb adj., 20mm thru-axle, 170mm travel
  • cartridge bearings
  • STEM Specialized DH, forged, 35mm length, 4-bolt, 31.8mm
  • FRONT BRAKE Avid Elixir 1, metallic pad, HS-1 rotor, 200mm
  • REAR BRAKE Avid Elixir 1, metallic pad, HS-1 rotor, 180mm
  • BRAKE LEVERS Avid Elixir, 1 hydraulic disc, tool-less reach adj.
  • SHIFT LEVERS SRAM X4, 8-speed, trigger
  • CASSETTE SRAM PG-830, 8-speed, 11-32
  • CHAIN KMC X-8, 8-speed, reusable Missing Link
  • CRANKSET Truvativ Ruktion, 165mm, w/ Status guide
  • CHAINRINGS 34T steel
  • BOTTOM BRACKET Truvativ Howitzer XR, oversize sealed outboard cartridge bearing, 73mm shell
  • PEDALS Alloy platform, 9/16”
  • REAR HUB Specialized disc, bolt-on 135mm, 36h
  • FRONT TIRE Specialized Butcher SX, 2Bliss Ready, 60 TPI, aramid bead, dual-compound, 26×2.3”
  • REAR TIRE Specialized Butcher SX, 2Bliss Ready, 60 TPI, aramid bead, dual-compound, 26×2.3”
Status I
Status Geometry
Status Frame
Status II
Status Pricing:
Status FSR II $3,300.00 August 2012
Status FSR I $2,500.00 July 2012
P26
P26 Cyan
P-Slope
P-Slope
P3 Soderstrom
P3 Soderstrom
P3 Soderstrom / Berrecloth
Pricing / Availability
P3 $1,400.00 September
P3 Frame $550.00 August 2012
P26 Pro $1,100.00 August 2012
P26 AM $830.00 August 2012
P.Slope TBD
if you missed the 2013 Demo post we did, be sure to check that out as well
