2013 SRAM XX1 Drivetrain 1×11 Details – Cranks – Derailleur – Cassette – Shifter
7/2/2012 : sicklines
, 2013 SRAM XX1 Drivetrain 1×11 Details – Cranks – Derailleur – Cassette – Shifter
Today SRAM has revealed some of the details of their brand new XX1 drivetrain system. It’s a 1×11 system that utilizes a 10-42t rear cassette with a specially crafted rear derailleur. Check out some of the details inside from SRAM.
SRAM XX1 was built with a dedicated 1X drivetrain philosophy—making it simpler, lighter and more durable than any other.
To start with the cranks, they feature X-SYNC™ which is A CNC- machined , “wide tooth, narrow tooth” pattern is repeated a round the entire chain ring , which mirrors the XX1 chain’s inner and outer links.
  • A new tooth profile alternates thickness by inner and outer links
  • Carbon arms with forged aluminum spider
  • Six ring options : CNC-machined rings (28-30-32-34-36-38)
  • New spider design allows for easier ring changes
  • Wide/narrow Q factor cranks for BB30 and GXP
  • Weight: 650 grams with BB approx
X-Horizon X1 Rear Derailleur
Features roller bearing clutch, cage lock, 220g weight (claimed), horizontal parallelogram, and more.
XX1 Cassette – FIRST OF ITS KIND
Ranging from 10- to 42-teeth, the 11-speed X-DOME™ delivers an incredibly wide gear range while maintaining even, optimized steps. The singleunit cassette combines with the XD™ driver body for a superior connection to the wheel.
  • 11-speeds (10-12-14-16-18-21-24-28-32-36-42)
  • Bearing design and ratchet mechanism steadied by XD driver body
  • Creates more stable hub connection
  • Gear steps optimized across entire range
  • Wheels equipped for XD driver body available from SRAM and DT Swiss
XX1 TRIGGER SHIFTER – quick on the draw
  • SRAM 1X11 X-ACTUATION™ for precise and dependable 11-speed performance
  • Multi-adjustable trigger shifter
  • MatchMaker X compatible
  • Carbon cover and adjustable carbon pull lever
  • Full Gore Ride-On cable system
XX1 GRIP SHIFT – Seismic Shift
  • SPEED METAL™ shift indexing
  • ROLLING THUNDER™ ball bearing technology
  • JAWS™ lock-on grip technology
  • Carbon cover
XX1 CHAIN -POWERFUL CONNECTIONS
The XX1 chain represents the latest breakthrough in a long line of precise, light-weight chains from SRAM. It’s designed to deliver the greatest strength and reliability to a drivetrain that doesn’t have to make compromises for front shifts.
  • New 1X11 XX1 specific chain
  • Designed for maximum strength and wear resistance
  • Proprietary link finish provides improved life span
  • 11-speed power lock
