13
e.thirteen by the Hive XC Single Speed Crankset, Shiftrings, and Heim 2
6/13/2011 : sicklines
For an up coming project bike we wanted to build a double chainring drivetrain setup. We turned to e.thirteen by the Hive to put together exactly what we were looking for. Their product combo of Shiftrings, Heim 2 chainguide, and XC single speed crankset is perfect for our build, which features products light enough for trail duty but durable enough for freeride and park riding.
Shiftrings
e.thirteen’s Shiftrings are one of their newest products. e.thirteen’s Shiftrings are a double chainring set that are ramped and pinned.
, e.thirteen by the Hive XC Single Speed Crankset, Shiftrings, and Heim 2(click to enlarge)
They are held together with torx screws and mate up perfectly to 104BCD single speed style cranksets (like their XC Single Speed crankset we’ll discuss later). They will not fit cranks with 4×64 BCD chainring tabs. They were also designed to be teamed up with their DRS and Heim 2 chain retention system.
, e.thirteen by the Hive XC Single Speed Crankset, Shiftrings, and Heim 2 (click to enlarge)
They’re available in either a 22/36T or 24/38T setup. We opted for the 22/36T setup for our application. They are made out of 7075 aluminum construction for durability, strength, and lighter weight.
The pin can be easily removed to accommodate a bashguard if needed. It is simply removed via a small hex bolt.
During our test riding so far the rings have shifted well on up shifts and down shifts. The pickup on the up shifts has performed as expected and downshifts are snappy. The Shiftrings mated up easily with e.thirteen’s XC single speed cranks and Heim 2 chainguide. We’ve had no issues with mis-shifts or dropped chains so far.
Specs:
  • BCD: 4 x 104
  • Available colors: Blackout
  • Compatibility: 9,10 spd
  • Sizes: 22/36T & 24/38T
  • ~$100
We’ve used the e.thirteen DH crankset very heavily for a while now and have been impressed with its performance. We have no doubt the XC Single Speed crankset will perform similarly since they share many of the same features.
Inside the box you’ll get:
  • T30 Torx wrench
  • T25 Torx wrench
  • 5 chainring bolt set + 5 extra bottom bolts that are for single ring usage
  • , e.thirteen by the Hive XC Single Speed Crankset, Shiftrings, and Heim 2(click to enlarge)
  • Wavy washer and savers
  • hive bottom bracket
  • hive bottom bracket tool
, e.thirteen by the Hive XC Single Speed Crankset, Shiftrings, and Heim 2(left to right) BB tool, BB cups, BB spacers, wave washer, thin BB spacers for setting crank arm gap (click to enlarge)
  • Crankset (175mm shown here) in blackout black anodization
  • Instructions (clean and easy to follow)
The arms on the XC Single Speed crankset are, as expected, not as beefy as the DH version. They still sport a similar streamlined profile and graphics. The crank arms are made out of CNC’d 7075 aluminum. They have 14mm of pedal thread engagement with pedal washers included. This should make the threads durable and highly unlikely of stripping out.
The spindle is the same 30mm diameter as the DH cranks which e.thirteen says gives them 15% more stiffness than their 24mm spindle competitors. The spindle also features their proprietary polygon interface (Based on DIN 32711 P3). It is designed to provide 100% surface contact between spindle and crankarm.  Unlike the other pinch or press fit systems out there currently, this one is designed to not have any issues related to wearing out and enable the crank to have full contact at all times for reliable long term performance.   If you want to read more on the standard, you can do so here.
The chainring tabs on the crankset are nice and thick. This should work well for our application, as the bashguard will likely be put to the test in various riding locations. Since there is only one set of chainring tabs we were able to mount up the Shiftrings easily for a slick double ring setup.
The bottom bracket comes with the crankset and features larger BB 6806 (7x30x42) bearings that are designed to carry 20% greater static load and increase BB durability. The bearings are easily serviceable, which is always nice. The notches on the BB are robust for non-slip installation. e.thirteen also includes the BB tool needed for the install. It works nicely with a Shimano/SRAM BB wrench or a hex key.
, e.thirteen by the Hive XC Single Speed Crankset, Shiftrings, and Heim 2bearing cover comes off for easy service (click to enlarge)
As noted above, the crankset includes all the spacers needed for proper installation of the cranks. The instructions for the crankset install can look a bit daunting at first (there are 8 steps) but as you work through them they make sense. The instructions are cleanly drawn and include all the important info and install tips you need for a correct setup.
Specs:
  • BB Shell: 68, 68E, 73, 73E
  • Chainline: 50.9mm
  • Arm Lengths: 170mm, 175mm, 180mm
Weights
Price
  • ~$250
Heim 2 Chainguide
The Heim 2 chainguide is a simple but effective means of chain retention for dual ring  setups. It is available in ISCG 05 or BB mount. The guide has a stepped roller that keeps the chain taunt and running smooth even when the terrain isn’t.
The guide is very low profile and tucks up nicely under the BB, out of the way from impacts. With our install the backplate sat very closely to the chainstay but didn’t touch. The backplate is designed with a built in stop so the chain and roller won’t rub the chainstay if it were to come in contact with an obstacle and move counterclockwise.
notice the backplate peeking just behind the chain (click to enlarge)
The Heim2 can be bought as just the chainguide or with a Turbocharger bashguard. We wanted the extra protection of a full bashguard because the project bike will see terrain varying from XC trail to Whistler park runs. You can get the guide in either a 36T or 40T capacity. Ours is a 36T to match with our Shiftrings.
Installing the bashguard with the shiftrings / crankset was easy. During our testing the Heim 2 guide has worked well with our Shiftrings keeping the chain in place over rough terrain and easily shifting up and down the front chainrings without error.
Specs:
  • Chainring size compatibility: 32T – 40T
  • Mount: ISCG 05 or BB mount
Weight
  • Heim 2 BB mount guide 58g
  • 36T Turbocharger 91g
Price
  • ~$100 Heim 2 with Turbocharger
If you’re in the market to put together a front dual ring drivetrain this setup is hard to beat. It’s lightweight, durable, and functions well together. We plan on bashing on this setup for a while putting our project bike through its paces. Check back soon to see what bike we put this on.
