2012 e.thirteen by the Hive LG1 TR, 4 x 120 Guidering, and Geared Hubs
4/16/2011 : sicklines
e.thirteen by the Hive had a slew of new products at Sea Otter. They had a new guide, guiderings, and geared mountain hubs. Check out all the details inside.
Geared Hubs
e.thirteen has released their hubsets for XC and AM use. The XC hubs are all aluminum while the AM hubs have a carbon body bonded with aluminum flanges like chub’s hubs. Both hubs offer interchangeable axle end caps to switch between axle sizes.
, 2012 e.thirteen by the Hive LG1 TR, 4 x 120 Guidering, and Geared Hubs
Using the same internals across all hubs, e.thirteen worked hard on the freehub design on their hubs in order to give the hubs a high amount of engagement points (60), while still maintaining low drag. They have designed their own system on their own versus using an off the shelf Taiwan system like many other manufacturers. The freehub system uses 3 pawls with 6 degrees of engagement for increased traction. Each of the pawls has 2 engagement points. Both engagment points lock in place at the same time. This basically disburses the load more efficiently, increasing durability.
You’ll notice the flanges are very large on the e.thirteen hubs. This is a trait they’ve brought over from chub that allows the hubs to build up very stiff and strong wheels due to the larger flanges. Theses hubs will be available in 6 bolt disc only, no centerlock.
At Eurobike e.thirteen plans to release their full wheelsets featuring these hubs.
AM Rear Hub
QR version (click to enlarge)
12mm version (click to enlarge)
  • flange material: 6061-T6
  • flange drilling: 28, 32
  • shell material: UD carbon fiber
  • axle width: 135mm / 142mm
  • axle standard: QR or 12mm
  • disc: ISO 6 bolt
  • color: black
  • weight: 350g (claimed)
AM Front Hub
20mm version (click to enlarge)
  • axle width: 100mm / 110mm
  • axle standard: 15mm or 20mm
  • disc: ISO 6 bolt
  • color: black
  • weight: 180g (claimed)
XC Rear Hub
  • flange drilling: 24, 32
  • shell material: 6061-T6
  • disc: ISO 6 bolt
  • color: black
  • weight: 295g (claimed)
XC Front Hub
15mm end cap (click to enlarge)
QR end cap (click to enlarge)
  • axle width: 100mm
  • axle standard: 9mm QR or 15mm
  • disc: ISO 6 bolt
  • color: black
  • weight: 165g (claimed)
LG1 TR
The LG1 TR is essentially a LG1+ without a bash. It is designed for trail 1×10 / 1×9 riders that don’t need bashguard protection and 4x riders. It is a step up in retention from the XCX.
LG1 TR (click to enlarge)
Features:
  • backplate: 6061-T6
  • wearplates: adjustable w/ ring size indicator
  • hardware: captive gold
  • lower armature: 3 position adjustable
  • chainring range: 33-38t
  • ISCG standard: ISCG ’05, ISCG Old, and BB mount
  • roller: tech 3 stealth idler
  • colors: black or white
  • weight: 118g (claimed)
  • Available within the next month
  • MSRP $129
4 X 120 Guidering
They have created a Guidering for cranksets with a 4 x 120 bcd (eg SRAM XX) to enable riders to run a single ring setup. They’ve got an  offset feature on the tooth profile specific to this chainring which allows the guidering to be ran facing in or out to get an different chainline. They’re made out of 7000 series aluminum and will come in sizes from 37 to 40t. They should be available shortly at $50 MSRP.
4 x 120 Guidering (click to enlarge)
4 x 120 Guidering tooth detail (click to enlarge)
See more [2011 Sea Otter Classic] content
