2012 crankbrothers Mallet & 5050 Pedal Lineup
4/15/2011 : sicklines
, 2012 crankbrothers Mallet & 5050 Pedal Lineup
2012 5050-3 and mallet-3
crankbrothers has revised their pedals for 2012. At this year’s Sea Otter Classic they showed off their revised 5050 platform pedal as well as a new mallet lineup.
Both the mallet and 5050 completely redesigned for 2012. The general profile is quite a bit slimmer slimmer profile as you can see.
The 5050 is available in two models, 3 (high end) and a 2 model (base level).
5050-3 (click to enlarge)
The 5050 3 series pedal as you can see has additional CNC machining done as well as a brighter finish.
  • 433g claimed
  • platform is a combo of a two piece aluminum + polycarbonate
  • The spindle is forged scm435 chromoly steel
  • inner bearing uses a needle bearing
  • outer bearing cartridge
  • traction pins 10mm adjustable
  • color – black&red
  • msrp $100
5050-2 (click to enlarge)
The 5050 2 Series pedal is a more budget oriented pedal, doesn’t have the same CNC pockets, but uses a light bushing instead of the needle bearing on the 5050-3.
  • 428g claimed
  • inner bearing uses a bushing
  • color – black&silver
  • msrp $80
The mallet lineup receives a new spindle and press fit internals from the eggbeater and candy family. Available in three models 3(high end), 2, and 1( base level).  The mallet 3 inner bearing uses a needle bearing and the mallet 1&2 use a bushing.
adjustable pins on the mallet-3 (click to enlarge)
The revised mallet body receive a material re-make of sorts as it now uses a polycarbonate as well as aluminum on the mallet 3 and 2.  The mallet 1 uses a full polycarbonate body.  All mallets get the forged scm435 spindle.
mallet-1(click to enlarge)
mallet details
Expect the pedals come in early summer, in the June time frame.
See more [2011 Sea Otter Classic] content
