2011 Canfield Brothers Jedi
2/23/2011 : sicklines
The Canfield Brothers have completely reworked their 2011 Jedi downhill race bike. Almost everything on the bike is new. Check out a video with Chris Canfield going over the changes as well as many detail photos.
Video
, 2011 Canfield Brothers Jedi
“Rearward wheel path tuned for speed and cornering domination on the track. Nothing rolls faster or brakes smoother giving you the speed advantage to WIN!” – Canfield Brothers
Features:
  • 7005 Aluminum frame
  • 150 x 12mm Hub Spacing
  • 83mm BB Shell
  • Fit up to a 2.7 tire (improved clearance on this new design)
  • 20mm max bearings
  • Replaceable rear derailleur hanger
  • Dedicated Thru Axle
  • Titanium pulley cog
  • 8.1″, 8.3″, and 8.5″ travel settings.
  • Progression settings – Linear(top shock mount hole) to more progressive (bottom hole)
full 1.5 headtube (click to enlarge)
Build Specs:
  • Recommend fork length – 8″
  • Shock Specs – 8.75″ x 2.75” (222mm x 70mm) with 22mm x 8mm hardware
  • Bottom bracket – 83mm x 128mm
  • Seat post – 30.9mm
  • Seat clamp – 35mm
  • Rear dropout spacing – 150x12mm through axle (included)
  • International standard disk brake mount
  • 05 ISCG tabs for a UPPER PULLEY Chain guide (Custom extra wide MRP G2 included
  • Headtube – 1.5″
the shock has adjustable mount holes to vary the amount of travel and progressiveness (click to enlarge)
the idler pulley has a new design (click to enlarge)
the chainstays are a bit shorter on the new Jedi for quicker handling (click to enlarge)
Lance Canfield aboard his new Jedi (click to enlarge)
  • 10.75lb with coil shock (claimed)
  • MSRP: $2,900.00 USD
Available Frame Color(s):
  • Anodized Black
  • Titanium Grey
Available Link Color(s):
  • Black
  • White
  • Blue
  • Red
Frames will be arriving in March. Contact Canfield Brothers to place your pre-order. They will only be producing 100 frames.
