2010 Interbike: 2011 Twenty6 Prerunner Pedal and F1 Stem
10/12/2010 : sicklines
For 2011 Tyler at Twenty6 Products has redesigned his popular F1 direct mount stem and Prerunner pedals. Check inside for details on the improvements and updates.
All of Tyler’s parts are made in his machine shop in Bozeman, MT. He loves machining bike parts and each year he continues to try and create better parts while still keeping them lightweight.
2011 Twenty6 Products F1 Stem
, 2010 Interbike: 2011 Twenty6 Prerunner Pedal and F1 Stem
The F1 stem has been redesigned to be stronger for 2011. The stem now sports a 2-piece design instead of the 3-piece from previous years.
Overall the stem seems a more supported design but still weighs in around the low 140 gram range according to Tyler. It is still adjustable but will be available in 2 adjustable sizes for 2011, 40/45mm and 50/55mm.
Features:
  • 31.8mm clamp
  • Made in the USA
  • 6061 T6 Billet aluminum
  • BoXXer standard mount (BoXXer, FOX 40, Manitou Dorado, etc)
  • Numerous colorways
red anodized finish (click to enlarge)
2011 Twenty6 Products Prerunner Pedals
The Prerunner pedal has also been revamped for 2011. Tyler has added a lot of features to help make the pedals stronger and offer more traction. The axle is now wider and larger which makes it stronger as well as accommodate a wider pedal body. The pedal body offers a wider platform with extra material added around the pin placements for better pin retention under impacts. The pins themselves have also been updated to a hollow design for 2011. Another change was the addition of a sealed bearing at the end of the axle to allow the pedal to spin a bit more freely compared to their full bushing setup from previous years.
cutaway (click to enlarge)
Interbike Show Bike
Tyler had a completely custom show bike on display at Interbike. A lot of the parts were custom powder coated and etched in twenty6 fashion.
[More 2010 Interbike Coverage] [Twenty6 Products Website]
