2010 Eurobike: 2011 Sunn
10/11/2010 : sicklines
The Sunn Team will be testing a new Radical next season.  While the frame might look similar as the previous Radical, there’s a lot of details that have changed. See the details on this bike and a few of their other bikes including Nicolas Vouilloz’s Sunn Chipie bike inside.
Sunn Radial
This is the current Sunn Radical that their World Cup team ran this year.  This version has a pivot right behind the bottom bracket unlike the Radical prototype version that you can see a little further down.
, 2010 Eurobike: 2011 Sunn
Current Sunn Radical (click to enlarge)
sunn radical lower pivot (click to enlarge)
2011 Sunn Radical Prototype
  • 83mm BB, 150mm rear end
  • Tapered Headtube
  • Concentric BB Pivot
  • steel rear end, aluminum front end
  • slacker (1º)
  • slightly lower bottom bracket
  • low shock placement
Big bearings are used in the suspension of this new prototype Sunn Radical.  Additionally, the BB shell is a concentric pivot.
Underside look at the Sunn Radical.  The rocker link rotates around the bottom bracket.
This prototype has some big bearings in it.  The drive side houses two cartridge bearings and the non driveside has one in the BB pivot area.
There will be an extension piece that connects to the lower shock mount (click to enlarge)
This is where the steel rear end mates with the alloy front triangle.
The prototype will feature a tapered headtube
Replaceable rear hanger.  Typically with a steel rear end you might not see a replaceable derailleur hanger but Sunn has integrated one in their design.
This isn’t the first time Sunn has used different front/rear triangle materials. You can see Nicolas Vouilloz’s Sunn Chipie downhill frame below that he piloted to some success back in the day.
Nicolas Vouilloz Sunn Chipie (click to enlarge)
2011 Sunn Charger Prototype
A New enduro style bike from Sunn. It features 170mm of rear wheel travel and like the Radical Prototype has a steel rear triangle.
Tapered headtube with integrated cable routing
Watch as team Sunn Enduro with Anne Caroline Chausson, Simon André and Yannick Pontal take their Chargers out for some riding.
2011 Sunn Shamann
2011 Sunn Kern
[More 2010 Eurobike Coverage] [Sunn Website]
