2010 Interbike: 2011 Elka Stage 4 Fork Cartridge and Updated Stage 5 Shock
9/26/2010 : sicklines
Elka had a brand new fork cartridge on display as well as a highly updated Stage 5 shock. Check inside for a video with Patrick Tellier going over the features of the new cartridge as well as the updates to the Stage 5 shock for 2011.
Features:
  • Fits: FOX 40, 2010 BoXXer, FOX 36
  • Designed to be very easy to install as there is little that the consumer needs to do to install this new damper.
  • Low maintenance – The system separates damping oil from lubrication oil. Elka says most users won’t need to service the cartridge but once a year and they should be able to get by with just lubricating the seals and replacing lubrication oil in the lowers during a season.
  • Nitrogen pressurized design utilizing piston and shim stacks.
  • Pressured cartridge has ~40psi so you will most likely have to drop the spring rate on your fork to compensate.
  • Hard anodized
  • External compression (~18 clicks currently low speed) and external low speed rebound adjustable (25 clicks currently).
  • Internally the fork is shimmed and allows Elka to tune the cartridge system for different riders needs and wants (high/low rebound & compression)
  • $495 USD
  • Available soon, in limited production
Three tunes will be available
  • Pro-WC
  • Medium-Average tune designed for a more average racer or those looking for a bit more performance
  • Soft version that is designed for the recreational rider
, 2010 Interbike: 2011 Elka Stage 4 Fork Cartridge and Updated Stage 5 Shock
Low speed compression adjust on top (click to enlarge)
Rebound adjustment at the bottom (click to enlarge)
2011 Elka Stage 5 Shock
Updates:
  • New clear anodized finish for more neutral color and Elka says it helps keep the shock cool
  • Thicker shaft anodizing
  • Changed a compression circuit thread pattern to stop clicking some users experienced
  • Updated rebound jet to a 1 piece design instead of 3 piece to reduce squeaking sound and standardize # of clicks across all valvings
  • Same price as last year – $450 for shock, $45 for steel spring, $10 or $15 for shock hardware
notice the new silver shock body finish (click to enlarge)
Elka works closely with manufacturers in order to get shock tunes set up for each bike model. For 2011, the Elka Stage 5 shock will be an optional upgrade with many companies.  Check with Elka or your bike company to find out more.
2011 Mongoose Boot'R Romaniuk version (click to enlarge)
2011 Santa Cruz Driver 8 (click to enlarge)
2011 Foes Hydro (click to enlarge)
2011 Turner DHR (click to enlarge)
2011 One Ghost (click to enlarge)
2011 Cove Shocker featuring a slightly lower bb and slacker HA, lighted up as well this year (click to enlarge)
[More 2010 Interbike Coverage] [Elka Suspension Website]
