2011 Shimano XTR M980
6/27/2010 : sicklines
, 2011 Shimano XTR M9802011 Shimano XTR M980 Gruppo
Shimano has officially announced the new 2011 Shimano XTR M980 Gruppo.  Check inside for the details.
2011 XTR M980 Product Information
Rider Tuned
IRVINE, Calif June 21, 2010 — New XTR M980 acknowledges the uniqueness of the different disciplines that the sport of mountain biking has evolved into. XTR’s Rider Tuned philosophy allows a rider to choose drive-train and braking options that best fit their style, use, and terrain. With Rider Tuned component options, XTR remains a relevant fit for any enthusiast or professional.
XTR’s Dyna-Sys drive-train results in greater efficiency and shifting stability – regardless of terrain, bike, or riding style. Options for multiple doubles or a triple further enhance a purpose-built drive-train solution.
The completely revamped XTR hydraulic brake system also features options that suit extreme trail use to lightweight cross-country. Servo-Wave precision control, ICE Technologies heat and fade resistance, and a variety of rotor sizes allow enthusiasts to perfectly match braking performance to their trail of choice.
New XTR with Dyna-Sys continues to offer benchmark performance and efficiency with unprecedented options allowing the rider to choose their optimal set-up. New XTR is Rider Tuned.
Ice-Tec
Shimano is introducing a completely new cooling technology for disc brakes named “Ice-Tec”. Ice-Tec brake pads and rotors significantly reduce heat build-up in the disc brake system. This in turn reduces fading, which assures consistently high braking performance even on long downhill stretches. It also results in longer pad life and substantially quieter braking.
Ice-Tec brake pads have been provided with an aluminum radiator fin with a stainless steel two layer back plate structure. Ice-Tec rotors have an aluminum core sandwiched in stainless steel for improved heat dissipation.
I-Spec
The new XTR offers an integrated mount system for the brake lever and shift lever, named “I-Spec”. With I-Spec, only one clamp band is needed which looks good and saves space on the handlebar besides saving around 10g. Horizontal microadjustment is possible for a customized set-up.
2011 XTR XC group (click to enlarge)
2011 XTR AM group (click to enlarge)
2011 Shimano M980 XTR Specifications:
RD-M980 – XTR Shimano Shadow Rear Derailleur
, 2011 Shimano XTR M980M980 GS (medium cage) rear derailleur (click to enlarge)
, 2011 Shimano XTR M980M980 SGS (long cage) rear derailleur (click to enlarge)
  • Low Profile Shimano Shadow rear derailleur design
  • Top normal spring design to mesh with the more common choice of RapidFire shifters for trail / all-mountain riding
  • Main body spring tension works well with full outer casing and creates more consistent shift effort throughout entire cog range
  • Carbon fiber outer pulley plate for light weight / Aluminum inner pulley plate for rigidity and durability
  • Sealed bearing guide and tension pulleys
  • Available in medium and long cage (GS and SGS)
  • Total capacity: 41T (SGS), 35T (GS)
  • Estimated weight: 175g
FD-M980 / M981 Triple and M985 / M986 Double Front Derailleur
, 2011 Shimano XTR M980M980 front derailleur – view more models in the gallery (click to enlarge)
  • Specific 10s cage design
  • Available in Top Swing, conventional, or E-type configurations to mount on most any frame
  • Multi-Access bolt for easily securing cable fixing bolt
  • Adaptable clamp means one size fits all for 28.6, 31.8, 34.9 and multi-pull allows top or bottom cable pull.
  • Set screws are angle outward for easier adjustment on some full suspension designs
  • Clamp band positions the same for 9 and 10s versions
  • Cage profiled for more tire clearance and specific compact cage for double
  • Estimated weight: 125g
SL-M980 RapidFire Plus Shift Lever for double and triple
, 2011 Shimano XTR M980M980 shifter (click to enlarge)
, 2011 Shimano XTR M980M980 I-Spec shifter allows for integration with the XTR brake lever (click to enlarge)
  • Front shifter features mode converter for use on either double or triple front chainwheel
  • VIVID index creates tactile rider feedback while maintaining low, linear shifting effort across the entire cog range
  • Instant release for quick accurate shifting and multi-release for shifting several gears at a time
  • 2-way release trigger allows thumb or finger actuation
  • I-Spec clamp options for lightest weight when combine with XTR brake levers
  • Multi-bearing construction for greater durability and reduced effort
  • Estimated weight: 195g/pr (I-Spec), 207g/pr (traditional clamp)
FC-M980 Front Chainwheel
, 2011 Shimano XTR M980M980 38t-26t crankset (click to enlarge)
, 2011 Shimano XTR M980M980 42t-32t-24t crankset (click to enlarge)
  • Triple or double / 42T-32T-24T or 38T-26T trail inspired gearing
  • Dyna-Sys gearing for greatest efficiency and stability
  • Hollowtech II design maximizes stiffness while keeping weight to a minimum
  • HG-X chainring tooth profile and Dual Spike provide unparalleled assertive front shifting
  • Precision two-piece construction for perfect chainline and chainwheel alignment.
  • Carbon / Titanium composite middle ring adds rigidity for better shifting, increases service life, and smoothly delivers powers to the cassette.
  • Outboard bearings maximize stability and stiffness
  • Estimated weight: 755g w/threaded BB
FC-M985 Front Chainwheel
, 2011 Shimano XTR M980M985 40t-28t crankset (click to enlarge)
  • Double / 40T-28T, 42T-30T, and 44T-30T XC and race inspired gearing
  • Q-factor reduced by 3mm per side compared to triple
  • Estimated weight: 698g w/threaded BB
CS-M980 Cassette
, 2011 Shimano XTR M980M980 cassette (click to enlarge)
  • 3 piece spider arm construction is light and rigid
  • 5 largest cogs titanium for lightweight and durability
  • 11-13-15-17-19-21-24-28-32-36 and 11-13-15-17-19-21-23-26-30-34
  • Alloy lock ring
  • Estimated weight: 255g
CN-M980 HG-X Chain
, 2011 Shimano XTR M980HG-X chain (click to enlarge)
  • HG-X directional chain specifically designed for MTB use
  • Inner and outer plates feature asymmetrical design to optimize front and rear shifting
  • Special plate chamfers help shed mud
  • Zinc-alloy plated for maximum durability
  • Hollow link pins for lightest possible weight
  • Uses standard connecting pin
  • Estimated weight: 259g
BR-M985 and BL-M985 – Hydraulic Brake System designed for XC and Race
, 2011 Shimano XTR M980M985 brake lever (click to enlarge)
, 2011 Shimano XTR M980M985 brake caliper (click to enlarge)
  • Integrated barrel reservoir design with split clamp is compact, light weight and easy to work on
  • 13mm wide two finger brake lever with ergo pivot offers efficient input, smooth operation and features anti-slip dimples on surface
  • Over-sized full ceramic piston is light weight, rigid and insulates the system from heat
  • One piece caliper is incredibly rigid and has a lightweight aluminum banjo for universal fit
  • Higher Power hose (compares to Saint SM-BH80)
  • One-way bleeding and improved oil routing through the caliper results in higher integrity and quicker bleeds.
  • Al back plate with resin or Ti back plate with metal compound brake pads offer the best blend of lightweight and tunable braking power
  • I-spec compatible
  • Estimated weight: 215g front / 229g rear
BR-M985 and BL-M988 – Hydraulic Brake Caliper System designed for Trail / AM
, 2011 Shimano XTR M980M988 brake lever (click to enlarge)
M988 brake caliper (click to enlarge)
  • Short stroke Servo-Wave mechanism has less freestroke and 25% greater lever input to suit more aggressive riding
  • 14mm wide two finger brake lever with ergo pivot offers efficient input, smooth operation and features anti-slip dimples on surface
  • Ice Technologies finned brake pads come standard for maximum heat control and fade reduction
  • I-spec compatible
  • Estimated weight: 247g front / 261g rear
SM-RT98 – Ice Technologies Rotor
, 2011 Shimano XTR M980SM-RT98 L rotor – view more rotor models in gallery (click to enlarge)
  • Three layer construction: Aluminum between Stainless Steel layers for optimal heat dissipation
  • Aluminum spider for precise and true final product
  • Heat related fade reduced by 35% and pad life improved
  • 4 sizes available: 203mm, 180mm, 160mm, and 140mm
  • Estimated weight: 126g / 160mm
PD-M980 – SPD Clipless Pedal
, 2011 Shimano XTR M980M980 clipless pedal (click to enlarge)
  • The body has improved mud shedding capabilities due to an oval shaped axle body housing, a more slim profile to the axle body, and offset bindings to allow debris to better flow through the pedal
  • Power transfer efficiency is improved by increasing shoe and pedal body contact by 270% over PD-M970.
  • Wider bearing placement also provide great pedaling stability and bearing durability
  • The new axle body is also lighter, reducing weight by 15g vs. PD-M970
  • Continues to offer trademark SPD clipless pedal performance
  • Estimated weight: 310g/pr
PD-M985 – SPD / Platform Trail Pedal
, 2011 Shimano XTR M980M985 clipless pedal (click to enlarge)
  • A new platform designed specifically for trail use
  • 158% more shoe/pedal contact vs. M980 with a 5.8mm wider platform
  • Wider bearing placement provides great pedaling stability
  • Integrated pedal cage allows for continuous pedaling even when not clipped in and better pedaling stability when cleats are engaged
  • The cage also provides binding protection from rocks on rough trails
  • Oval shaped axle body housing allows mud to more easily flow through
  • Estimated weight: 398g
FH-M988-AX75 / FH-M985 / FH-M988 / HB-M988 / WH-M985 / WH-M985-F15 / WH-M988-F15 / WH-M988
, 2011 Shimano XTR M980M985 rear hub – view more models in the gallery (click to enlarge)
, 2011 Shimano XTR M980M988 wheel – view more models in the gallery (click to enlarge)
  • XTR will also feature new hub and wheel options.  Both will address options for E-thru 15mm front as well as 12mm E-thru (12 x 142mm) for the rear axle.
[2011 Shimano M980 XTR Gruppo Gallery] [Shimano Website]
