2011 SRAM X.0 launch
Last night, SRAM unveiled the new 2011 X.0 and X.9 . Inside you can see the all new 2011 Sram X.0 Gruppo. Be sure to also check out the X.9 gruppo that we’ve also posted.
X0 10-Speed Rear Derailleur
Options: Available in Long, Med. and Short cage
Claimed Weight: 190 grams
Technology: Exact Actuation Ratio, Direct Route Technology
Speeds: 10
Compatibility: Exact Actuation Ratio, 10 Speed; 36t maximum
Material: Forged Aluminum, Carbon Fiber Composite, AL-7075-T6 / Stainless Steel
Pulley: Bearings Sealed Bearing
Exact Actuation 10 speed
New Chassis – focused design for all conditions and usage
Super light weight and durable
4 graphic colors available, Black, Red, Gold and Blue
36 tooth cassette capability
X0 10-Speed Front Derailleur
Claimed weight: 130g
Speeds: 2X10 and 3X10
Cage Material: Steel
Clamp Material: Aluminum
Chainstay Angle: 66-69
Seat Tube Mount: High Clamp / Low Clamp (31.8, 34.9, 38.2) Low Direct Mount (S1, S3) and High Direct Mount
Cable Routing: Top or bottom
X0 10-Speed Trigger Shifters
Claimed weight: 232g (2X10)
Compatibility: Exact Actuation RD and FD
Matchmaker: MatchMaker X
Clamp: Adjustable
Release Lever: Composite
Pull Lever: Forged AL, adjustable
Inner Wire: 1:1
Main Bolt: Stainless
Barrel Adjuster: Yes
Cover: Aluminum
SRAM’s 2X10 and 3X10 Exact Actuation
The first patented adjustable trigger shifter
Super light weight
MatchMaker X and Matchmaker upgradable
X0 10-Speed Crank Sets
BB BB30, PF30, GXP, PF GXP Claimed weight 198g
Chainring Materials Alloy
Chainring options 2X: 26-39, 28-42 3X: 22-33-44
Compatible Chain Type: SRAM 10 Speed
BCD: 80/120
Crank Length: 175 or 150
Crank Arm Material: Carbon composite
X-Glide 2X10 and 3X10 shifting technology, 26-39, 28-42 and 22-33-44 gearing
Machined 7mm AL rings
All new light weight carbon crank strong enough for trail riding
4 graphic colors: Red, Black, Gold, and Blue
New GXP Bottom Bracket System featuring Gutter Seal Technology
Available in PF30, BB30, GXP and GXP PF configurations
CNC machined chainrings
Team GXP Bottom Bracket
Bearings: Two Sealed Cartridge Bearings – Custom steel bearings.
Tungsten finish
Tech Feature Gutter Seal Technology – improves sealing against the elements
BB Shell Wide 68mm and 73mm
Avid X0 Brakes
Claimed weight: 333 grams (Front; Post Mount;160mm)
Rotor size: 160/185/203 G3 Clean Sweep
Caliper: 2 Piece Forged Aluminum
System: 2 Piston; Open System
Pads: Organic
Tooled reach and banjo adjustments
TaperBore Technology
Detented; tool free Contact Adjustment
MatchMaker X compatible
All new forged aluminum caliper
Forged aluminum lever body
New carbon lever blades
XG-1080 Cassette
Claimed weight 235g
Technology X-Glide and Exact Actuation
Recommended Chain SRAM 10 Speed
Lock Ring Material Aluminum
Sprocket Material Aluminum
Sprocket Finish Steel
X-Glide technology
X-Dome design with mud clearing open design
Eight of the cogs are CNC-machined from one block of billet steel
Incredibly light weight, precise and strong
Options 11-36 and 11-32
PowerChain 1091 Chain
Weight 257 Grams (114 links)
Closing Link PowerLock™ tool-less
connecting link
Pin Treatment Chrome Hardened Pins
Rivet Type Hollow Pin
Compatible Gears 10
