29
Spotlight: Spank Spike Director Stem and 777 Evo Handlebar
3/29/2010 : sicklines
, Spotlight: Spank Spike Director Stem and 777 Evo Handlebar
Spank offers a wide array of components that work well in a myriad of bike genres like downhill, freeride, all mountain, enduro, dirt jumping, and more. We have some of their newest cockpit parts in to check out. The Spike Director direct mount stem and 777 Evo handlebar are featured inside.
Spike Director Direct Mount Stem
The Spike Director is designed to fit the Boxxer standard mount that will work with any dual crown fork with this design.  The FOX 40 series, Boxxer series, BOS series, and Manitou Dorado series all accept this mounting pattern.
, Spotlight: Spank Spike Director Stem and 777 Evo Handlebar(click to enlarge)
The 2-piece stem is extruded, forged, and CNC machined out of 7075 T6 aluminum for high strength and low weight.
The Spike Director is currently available in a 50mm length and offers a low rise.
The stem accepts a bar clamp diameter of 31.8mm.
torque specs are printed at each bolt location (click to enlarge)
It comes with a custom snap-fit Spank top cap that has an o-ring on the inside of it that helps it fit snugly into the top spacer.
Stainless hardware is used throughout.
Colors: White/Black/Chrome
Weight: 152.7g
MSRP: $86.95
Spike 777 Evo Handlebar
On the surface, these may look like normal bars, but the spank bars have tapered sections inside to add more material in high stress areas. By using FEA analysis the Spank was able to apply their Dual Extreme Gradual Taper technology and 3 plane CNC bending for stronger construction and less weight.  Material is added and removed where Spank determined it was required to help bring some advanced handlebars to the market.
, Spotlight: Spank Spike Director Stem and 777 Evo Handlebar15mm rise chrome version (click to enlarge)
The bar is made from Spank’s Super Six alloy at a length of 777mm.The bars have a 9 degrees of back sweep and 4 degrees of upsweep.
They feature Impact Ends which means that they have a greater wall thickness at the tips to prevent impact damage and crushing during crashes.
, Spotlight: Spank Spike Director Stem and 777 Evo Handlebarbar ends have cut marks for easy trimming to preferred length (click to enlarge)
The Spank EVO line of bars are vailable in 5mm, 15mm, 30mm and 50mm rises.
, Spotlight: Spank Spike Director Stem and 777 Evo Handlebar15mm rise (click to enlarge)
, Spotlight: Spank Spike Director Stem and 777 Evo Handlebar5mm rise (click to enlarge)
They are only available in 31.8mm clamp diameter. The clamping area itself has special attention paid to it during the construction process so that is uniformly cylindrical for an improved bar-stem interface.
Weight: Black 5mm rise – 290.1g | Chrome 15mm rise – 293.3g
MSRP: $75.50
Alloy Lock-On Grips
This is the V2 version of Spank’s lock-on grips. They now include anodized alloy end caps.  They secure onto the bars with a 3mm allen bolt and come in three color options (black, chocolate, and white)
They are 130mm long and feature a knurled surface. The grip itself is thin much like a ODI Ruffian.
Colors: White, Black, Brown/Gold
Weight: 111g
MSRP: $22.50
For more SPANK products and details check out their website.
