Yakima HighRoller
The Product:
History:
Yakima started some 25 years ago creating durable and dependable “destination hardware”. Over the years the products have evolved using new technology and improving designs. Yakima strives to create products that are environmentally conscious, innovative, and user friendly. Their employees play as hard as they work using Yakima products themselves in the field to make sure the customer receives a quality product that will last. With Yakima the needs of the customer always come first. If you ever have any issue with a Yakima product, they’ve got a lifetime warranty to keep you safe and rolling.
Features:
The HighRoller is a very nice roof rack that has benefits that any cyclist can appreciate. Below we’ve outlined the key benefits to the Yakima HighRoller. The HighRoller is an upright bike carrier and holds the bike in place without contacting the frame. Loading and unloading the bikes is very easy, and makes the process of transporting bikes a lot faster than other roof rack options. The weight limit of each HighRoller rack is 50lbs so it can hold just about any bike with ease as even heavy downhill bikes are typically under 50lbs.
- The HighRoller has no problem handling disc brakes, thru axles, or funky suspension designs
- The HighRoller keeps your paint job looking pretty because it grabs onto your wheel and doesn’t touch the painted surfaces of your bike. The bike loads into the tray with ease and tightens easily by turning the outer knob.
- The HighRoller fits every tire we put in there. From super-skinny road tires to big bad 3-inchers, without any adapters or releasing tire pressure to force it to fit. If you’ve got to lift a heavy bike onto your roof, it’s nice to know you don’t have to mess with adapters or tools with this tray.
- Fits bikes with wheels from 20” to 29” in diameter. The Yakima adjusts for bikes of all sizes with ease and all without tools. The front wheel holder has an adjuster than has several detents that the adjuster can move into accommodate varying bike wheel sizes. All adjustable without any tools or adapters.
- One easy-to-reach main knob controls retention, adjustment and release (red button). The main control system is all controlled in one easy location. Push the red knob to release the front wheel. Wind the adjustment knob around to cinch the front wheel down securely between the front two arms.
- Super strong and wide wheel tray can hold anything from monster freeride bikes to small bikes with tassels on the handlebars.
- Folds down nicely when not in use to reduce noise, wind, and increase gas mileage.
- Integrated SKS cable lock for no worry security (Lock Core sold separately).
- Easy to adjust sliding wheel tray makes positioning rear wheel a breeze and fits a wide range of bike lengths. The rear wheel attachment is upgraded. No longer can the straps stray where they shouldn’t go. The sliding tray is a very nice feature and easily accommodates bikes of all sizes with ease.
- Double-sided wheel strap for use on either side of your car. No longer do you have to rotate straps on the wheel. It works on both sides with ease.
- Factory rack compatible with MightyMounts. In the event you have a stock rack from your car company, you can get mounts to mount the HighRoller to.
