Facebook Twitter RSS MPORA
Ultimate Support Tabletop Gram Scale
written by j.v.nixon
Product: Ultimate Support Tabletop Gram Scale
Price: $54.99 MSRP
Accuracy: accuracy is +/- 1.0 g, 0.1 oz. or 0.002 lb.
Warranty: 1 year
Purpose:
To weigh small parts (up to 3 kg.)
About the scale:
  • The scale is accurate to 1g.
  • The scale is made quite sturdy and sits quite well on a table.
  • The top of the scale features a clean metal surface for easy cleaning.
  • The scale runs on two AAA batteries and also features a place for an external power source (4.5V DC) so you can save on batteries if need be by plugging it into an AC adapter (sold seperatly).
  • The scale is mostly plastic and as a result is pretty lightweight but still durable.
  • The surface of the scale where you can put parts on it measure 5.5″ x 5.5″
  • The scale’s numbers are clear and easy to read. This scale can be read from a good distance away and has a nice font that is very clear and easy to read.
Features:
  • Auto off – Scale automatically turns off in the event you don’t place anything on it for awhile. This can save you batteries in the long run if you forget to turn off the scale.
  • Tare – You can tare the scale so you can put a small bucket on the scale and measure parts inside the bucket without the weight of the bucket affecting the measurement.
  • Mode - View weights in grams, ounces, and pounds. / oz / lbs
Using the scale:
Using this scale is very easy and there are minimal ways you can incorrectly mess up your readings which is great. The buttons are easy to see and are spaced nicely so you really can’t accidentally press the wrong button. I found the readings on the scale to be precise when compared to other more expensive desktop scale’s I have.
Suggestions on improvement:
  • I would like to see the top of the scale where you place parts be either rounded or a recessed surface in the center to hold parts easier. Often if you place a part on there that isn’t flat it can roll around or off the scale. You can remedy this easily by placing a small tub or container on the scale and placing your parts inside.
  • I would also like to see this tabletop scale have a higher capacity (perhaps up to 10 or 15 lbs). While 6.6lbs is perfect for weighing small parts it would be nice to weigh heavier parts on the scale as well.
Conclusion:
The Ultimate Support Tabletop Gram scale meets its goals of being Accurate, Versatile, and Durable. If you’re looking for a small scale to weigh parts off of your bike this might be what you’re looking for. It’s a lightweight accurate scale that can weigh parts up to 6.6 lbs. The buttons are easy to push and they give a responsive feel as well as a big visual indication of what is being done readily on the LCD display.
For more information and to see more products from Ultimate Support
[Suggested Online Merchant]
Online: www.UltimateSupport.com
phone: 1-800-525-5628 or 970-493-4488
email: bike.customersupport@ultimatesupport.com
