Point One Racing Split Second (Direct Mount) Stem
written by J.V. Nixon
The Point One Split Second (Direct Mount) stem mounts cleanly to any Boxxer standard crown. It is one if not the lightest direct mount stem we’ve come across and its stiffness is in line with the best of the best. Currently, the direct mount stem is offered in 50mm length and either a 25.4mm or 31.8mm clamp diameter. Additional sizes they say will be made to accommodate the desires of gravity riders everywhere. Made 100% in the USA with the precision we need more of in the mountain bike industry.
History:
Point One Racing is fairly new to the mountain bike scene, but they’ve got a history in machining high end parts and a love for the gravity mountain biker that shows in their designs. Every Point One product is designed in their state of the art facility in California where they’ve made some fine products beside Hewlett-Packard, Lockheed Martin, and the United States Military. The founders have experience in quality control and it shows in their final product. They use some very expensive equipment in their machining facility with tools like a Kitamura 400 5-axis Supercell on hand to produce some amazing parts.
“Quality Point One strives to bring their customers the best quality products on the market. How do we do this? Point One’s president/ Lead Engineer and Vice President both started out their careers as Quality Assurance Specialist in the manufacturing industry. Having that kind background is an invaluable asset when manufacturing such elite products. Point one has the best Quality Laboratory in the Bicycle industry. This is possible because Point Shares its quality facility with its manufacture which has been producing products for Lasers, missiles and radar equipment for over 50 years. Sharing facilities means Point One’s quality personnel are always on site during the manufacturing process ensuring only the best products. Pictures of our quality lab and techniques can be found on our manufactures website. BZMFG.com
Why quality is important? Quality is important because the bicycle market is flooded with low quality Taiwan made parts. Point One is offering an alternative to these low end parts by offering high quality American made products. Point one is going after the racing market where there is no substitute for quality products.” Scott Orehek (VP)
The Product:
The Point One Split Second direct mount stem is currently available in 25.4mm or 31.8mm bar clamp diameter and is 50mm in length with a zero degree rise. The finish, machining, and all the other steps are all done in the USA. While it may seem like manufacturing quality may have all gone overseas the Point One products are a testament to what hard work can do with a knowledgeable staff and solid equipment.
Point’s goal was not to create the lightest stem possible by itself, but to produce the best stem they could that was light as well as strong. After riding their direct mount stem for a good while now, it’s clear that this stem isn’t lacking in any way shape or form in stiffness.
The stem mounted up cleanly and easily to the crown and it offered a very wide clamping stance (55mm) on the handlebar.
Point passed along some tests that they performed against the top stems and it shows how the Point stems are essentially as stiff, if not stiffer, than just about every stem they tested against. They assured us they tested against the best of the best. The benefit to everyone is that you get a stiff stem that doesn’t weigh much at all.
Point plans on offering a titanium bolt option in the future but for now they will be using fastners from Tekbolt. Additionally, other products are in development like a specific spacer for their direct mount stem and more.
Part Year Real(g) Pic.
Point One Split Second (DM) all mounting hardware 2008 129
a
Suggested Improvements:
There isn’t really much we could suggest to improve with this product from a design standpoint. Esthetically, using black bolts would be a nice touch but isn’t necessary. More stem length sizes would be great to see as there is a lack of long direct mount stem options out there. Additionally the option for a titanium bolt kit would be a nice touch as well.
$119 MSRP
Conclusion:
Point really has outdone themselves. Their products show off their fine machining and manufacturing capabilities. At $119 for the stem it is also worth noting that the material, machining, inspection, plating, laser etching, testing, assembly are all done in the U.S.A. While machining in the U.S.A. seems to have either gone into a downward spiral, or very expensive, Point One Racing steps up big time to show what they can do.
The Split Second direct mount stem is as stiff as anything we’ve come across and feels even stiffer in some cases. With handle bars becoming wider and wider, weak points are easier to notice and the Point stem provides a solid interface that is as light as we’ve seen while still remaining stiff.
Point One’s tag line sums up almost perfectly what they have set out to do and so far they seem to be hitting the nail pretty square on the head.
“The difference between winning and loosing is often Point One. We truly believe in this sentiment. In racing winning or getting 2nd can be a fraction of a second so we design parts that are lighter and better. Giving you just enough to give you a Point One advantage.”
[Point One Racing Split Second (DM) Stem Gallery] [Point One Racing Website]
