Formula Bianco
In The Field:
Formula Bianco (click to enlarge)
The Formula Bianco’s are not only light, but they’re very powerful. If you’re looking to drop some weight off your braking system while most likely increasing the braking power, the Bianco might be what you’re after.
The Bianco’s are lighter than Juicy’s, are more powerful, and pack a lot of benefits over the Juicy’s. The Bianco’s aren’t as powerful as a full on downhill brake (Code / Gustav), but they’re definitely very capable.
The Bianco’s worked quite well and they never showed signs of fading or pumping up which was very impressive for such a tiny looking brake. The lever itself has a very nice feel to it and is perfect if you like one finger braking. The Bianco lever itself is fairly thin and you can wrap your finger around it nicely as there’s not much girth to it. The Bianco lever blade is a bit small in comparison to a lot of other brakes, but they pack a lot of power.
If you use the Bianco’s with 160mm or 180mm rotors, they offer what I think is a killer XC/AM brakeset. If you pair the Bianco with an 200mm or their 220mm rotor, it quickly becomes downhill worthy. Modulation on the Bianco is very good and controllable. The Bianco lever body is pretty durable but isn’t as crashproof as a downhill/freeride brake. The Bianco’s were silent while braking which was very nice, but they occasionally did have a “zing” and the busings in the lever did have some noticeable play.
Depending on what shifters you use, Formula does offer a mixmaster which can attach the brake and shifter together if you run the newer SRAM X.9/ X.0 shifters. If you run some older Shimano shifters, you might experience some interference or setup issues as the Bianco body is a bit wide where the shifter normally tucks under the lever body.
To give you a better idea of the makeup of the Bianco, we’ll take a look at the parts separately to understand better what the Bianco does.
