e.thirteen Ali Stem
written by J.V. Nixon
Introduction:
The e.thireteen Ali stem is designed to work in conjunction with the Rock Shox Boxxer direct mount standard. The Ali stem bolts directly to a boxxer standard crown. It offers great adjustability and has numerous benefits for those who choose to run the e.thirteen integrated stem.
Background:
e.thirteen components is a small, rider-owned and operated company that strongly supports dozens of grassroots races, series, contests and other riding events all over the world every year. Founded in 2001, e.thirteen’s innovative, functional, simple and lightweight chain retention systems have made them a world leader in this category, and the choice of top pro and amateur riders and mechanics alike. They support a worldwide distribution network and take great pride in offering devoted customer service.
e.thirteen Ali stem (click to enlarge)
Contnets:
- ALI stem 31.8mm
- 25.4mm adapters if you want to run a 25.4mm bar
- All necessary bolts
Features:
- Adjustable 45mm - 55mm reach
- Adapts from 31.8mm to 25.4mm with included shims
- Strong 7075 T6 construction
- Lightweight at 177 grams including all mounting hardware. (add 25g for 25.4 shims)
- 12.8 grade Dacromet hardware (Stronger than stainless steel bolts)
The Product:
The Ali stem has a very nice finish and a nice low bar height. Since this stem is a direct mount stem, in the event of a crash the bars won’t twist. Setting up the e.thirteen stem is a breeze and by using an e.thirteen Ali stem, you can cut a significant amount of steerer tube off as a result. In the picture below, almost 2†of steerer tube could be removed which cuts down on the overall system weight as well.
The stem will work with 25.4mm or 31.8mm bars. It comes with adapters if you decide to run a 25.4†bar
The Ali stem is stiff and is more responsive than your standard stem as it is bolted directly onto the top boxer crown which gives it a more solid and responsive feel.
There are a few areas where an integrated stem like this might raise an issue. The first is damaging a fork in the event of a crash. Any integrated stem poses this problem but it should never happen and is a rare occurrence if it does. The second is if you decide to use carbon bars, you’ll have to verify from the manufacturer if you can use this stem with your bars. Lastly if you’re running the bars at 45mm, a small bit of the stem will extend back and doesn’t sit flush against the crown edge and you can hit you knees on it. In 55mm mode, the stem sticks on the boxer crown well but still has a small bit of material extend past the back of the crown.
Suggested Improvements:
There isn’t too much that i’d change with the e.thirteen Ali stem but I would like better aondization on the stem as it can scratch fairly easily. In addition to the anodization, it’d be nice if the stem conformed to the crown a bit better around the edges so that there wasn’t any part of the stem overlapping on the crown.
$99.95 MSRP
Conclusion:
The e.thirteen direct mount Ali stem works great and offers a very low stack height, ample adjustability, and helps you direct your bike where you want it to go. You’ll be hard pressed to find an integrated stem that is lighter than the e.thirteen Ali stem.
You should be able to purchase this, and any other e.thirteen guide at any good bike shop or e-retailer. Contact chad@redbarnbicycles.com for some great prices.
See http://www.e13components.com for more dealer locations.
Contact support@e13components.com to verify compatibility if there’s any questions.
