Blur B1 Goggle Review
Goggle Body
Blur Optics designed a very solid body for a really nice set of goggles. The face foam felt great and the body offered good ventiliation.
Goggle Straps |
Goggle Side Vent |
Body Highlights
- The goggle strap has a silicon strip to help keep it on the helmet.
- The body is soft and flexible. This helps them be more durable and conform to faces of all sizes.
- There’s plenty of ventilation along the sides and foam to prevent any dirt or debris from entering.
- Four layer foam design to help keep sweat away while still maximizing comfort including a fleece layer.
- The Blur’s have a clean look to them and come in a variety of colors to fit varying rider styles.
- The silicon that is used in the straps to make them stick better to helmets was a solid line of silicon. There could’ve been a little bit thicker silicon but it stuck well enough.
Some improvements to the goggle body
- There are no prescription inserts available.
- The lenses are like typical motocross goggles and they aren’t the easiest to swap out if time is important.
- There is no rock or nose guard available.
- A slightly thicker layer of silicon would be nice as well.
- The inside of the body is black, but some sort of anti-reflecting coating would be a nice addition.
- It would be nice to see the face foam removable to allow for easy cleaning or replacement.
Frame Color options
- Black
- Blue
- Red
- Clear/Black
- Yellow
- Green
- White
