Adidas Evil Eye ClimaCool Pro S
Sunglass Body:
The Adidas Evil Eye ClimaCool body has a lot of technology behind it. On the surface, it seems like a conventional set of sunglasses, but there’s a lot to the body.
The Adidas Evil Eye’s come in two models, the Pro S, and the Pro L. The Pro S (one reviewed here) is the smaller, and the Pro L is a larger version.
SPXTM: Utilizing proprietary Adidas materials, the body is very flexible and durable. The frame overall is very lightweight and fits a variety of heads easily.
TRI.FIT Temple: The temple offers up to 8 degrees of angle adjustability. The sunglass arms have 3 specific spots that they can easily rotate into to help fit the cyclist better.
Quick - Release Hinge: The Evil Eye ClimaCool pro does not use any screws to hinge the arms and body together. This feature is priceless as the arms can pop in and out.
Double Snap Nose Bridge: The nose bridge is removable/replaceable. The material is hydrophillic and will not slip as you sweat. There are two positions available that you can adjust it to.
Ventilation: Teamed with the ClimaCool lens, the body has small holes for airflow through the frame without causing any eye irritation. Airflow through the frame helps keep your face cool, and the lens free of fog. The arms also have holes in them near the ears to similarly allow air to pass though them while still maintaining a secure fit.
The overall fit of the Evil Eye ClimaCool sunglasses is quite good. It can adjust to a variety of face sizes with the adjustable arms and it sits nicely on the face without being too close or too far from the eyes.
