| a |
| Complete | Year | Real(g) | Pic. |
| Complete 2008 Intense M6 Large | 2009 | 16714g / 36.85lbs |
| a |
If you’re looking for more weights, see our weight section.
The M6 is a lightweight frame and is relatively easy to build up to a very respectable weight. The longer stroke shock adds some weight from the damper and the longer spring. Upgrading to a TI spring is a good idea if weight savings is important to you.
Geometry:
Intense M6 geometry
We’ve upgraded our geometry illustrations with real number’s put into Linkage Bike Suspension Simulation.
Real data. Real numbers entered. Real results easy for you to see.
Click the picture below to see the Intense M6 in Linkage Bike Suspension Simulation. (flash required)
