2007 Transition Double
The Parts:
To know a bike, you have to know the parts on it. Listed below are the parts that made up our Transition Double.
Bottom Bracket: Deity
- 4130 Cro-mo spindle
- 48T splined
- Infinitely adjustable chainline
- Bottom bracket cups use 4 replaceable sealed cartridge bearings
Chain: KMC
Cog: Generic 18T
Crankset: Deity 4130 Crankset
Fork: 2007 Marzocchi Dirt Jumper 2
Frame: 2007 Transition Double
Front Tire: Maxxis 2.4 Holy Roller
Front Wheel: Transition Revolution 20mm
Grips: ODI Rogue lock-on’s
Handlebar: Deity 25.4mm
Headset: FSA Orbit MX w/ Transition top cap
Lockring: Recon
Pedals: Straitline
- 12mm spindle
- 14 stainless steel traction pins per side
- polymer bearings
Rear Brake: Hayes HFX-9
Rear Derailleur: Paul Melvin
Rear Rotor: Hayes 6″
Rear Tire: Maxxis 2.4 Holy Roller
Rear Wheel: Transition Revolution QR
Seat: Transition Park N Ride Jump
Seatpost: FSA
Seatpost Collar: TBC QR
Shock: 2007 Marzocchi Roco Air R
- Adjustable rebound
- Nickel Coated Body
- Linear Air Spring
- Fixed Negative Air
Sprocket: Deity 4BDH 36T
- CNC’d 7075 T6 aluminum construction
- 5mm thick 4B 104 design
- Compatible with 8 and 9 speed chains
Stem: Deity 25.4mm
- CNC’d 6061 T6 aluminum construction
- 50mm reach with 0 degree rise
