2007 Mongoose EC-D Review
The Parts:
To know a bike, you have to know the parts on it. Listed below are the parts that made up our Mongoose EC-D.
Bottom Bracket: Truvativ Howitzer Team
- CNC-Machined Alloy L & R Cups in Tech Silver
- 2 x Sealed Oversized Cartridge Bearings
- Super Strong Howitzer CrMo Spindle
Cables: Jagwire
Cassette: Sram PG 970 12-26t
- Lightweight performance cassette
- Heat treated cogs
Chain: KMC Z-9900
Chain Guide: MRP System 3 BB mount
- Recommended for use on bikes with a low-profile chainstay design
- For 36 to 40 tooth, single chainring
- Compact design for increased clearance
- ISCG adapter CH1596 for non-ISCG tabbed frame
Crankarms: Truvativ Holzfeller 175mm
Fork: Rock Shox Boxxer Team
- Travel - 203mm
- Spring - coil
- Spring Adjust - preload
- Damping Motion Control with BlackBox Speed Stack
- Damping Adjust - external rebound, low speed compression and floodgate, internal high speed shim stack
- Crown - forged aluminum with bolt hole pattern to allow direct mount stems
- Stanchions - 32mm 7000 series straight wall with low friction anodizing
Frame: Mongoose EC-D M/L Frame
- 6061 Aluminum w/ patented floating BB
- Replaceable 150 x 12mm thru-axle dropouts & disc mount
- 7.3-8.4†travel
Front Brake: Avid Juicy 7
- Pad Contact-Point Adjustment
- Tri-Alignâ„¢ Caliper Positioning Systemâ„¢
- Power Reserve Geometryâ„¢
- Ambidextrous
- Split Clamp/Matchmakerâ„¢ compatible
- Drip-free bleeding
Front Tire: Kenda 2.5 Nevegal Folding
Front Wheel: S-Type Sun Ringle Abbah 20mm
Grips: Mongoose Half-flange lock-on
Handlebar: Easton EA70 25.4 685mm
Headset: FSA Orbit Extreme Deep Cup
Pedals: Straitline
Rear Axle: Maxle 12 x 150mm
Rear Brake: Avid Juicy 7
- Ambidextrous
Rear Derailleur: Sram X.9 Med Cage
Rear Tire: Kenda 2.5 Nevegal Folding
Rear Wheel: S-Type Sun Ringle Abbah 12×150mm
Seat: SDG Belair ST
- Light weight EVA foam
- Stealth gray base
- Custom Topeak QR System tool bag mount
- Injection molded tail bumper for increased durability
- Multiple color and material options available
Seatpost: SDG I Beam
Seatpost collar: Stock QR
Shifter: Sram X.9
Shock: Fox DHX 5 9.5
- Coilover w/ piggyback reservoir
- Boost valve
- Adjustable ProPedal damping
- Adjustable tuning range
- Preload & rebound adjust
Spring: Fox 3.25 x 450
Stem: Easton Havoc 25.4 7°
Tubes: DH
