2007 Hope Moto V2
In the field:
Hope Moto V2 (click to enlarge)
The Hope Moto V2 brakes offer a lot of power, but in a very controlled manner. The lever feel can be tweaked nicely to just about any taste. If steep long descents are your forte and requires you to brake a lot, the V2 might be what you seek. The V2 vented rotors offered an immense advantage in keeping the system cool and working perfectly even under intense braking. If you thought a standard 8″ rotor was strong, the V2 vented rotor is even better. This comes at a price though, weight. The vented rotor is claimed to reduce heat by 15%, and it shows once you’ve used them on any descent. The brakes felt completely dialed down every run. Hope bleeds their brakes quite well from the factory and with Dot 5.1 fluid no less. If you’re a heavy weight guy and demand a powerful brake, the V2 with the vented rotor might even be overkill for you if you’re not riding steep long descents.
During the testing, there weren’t any issues with the brakes not working, or breaking. The braided stainless steel hoses were a nice touch. They offered strength over standard housing as well as a clear coat finish to protect it from damaging the frame. The Moto lever design is intended to provide stability and power. The Moto lever needs to be set inboard (see above picture) a bit more than any other brake I’ve used before. It has to be set in a lot more than a typical hope M4/M6/Mini lever. Perhaps too much depending on the length of your bar and your hand size.
Check out the individual features of the Hope Moto V2 system in the following pages as we break down the Moto V2 to illustrate what Hope has done with this powerful new brake.
