2007 Brodie Dissident
The Parts:
To know a bike, you have to know the parts on it. Listed below are the parts that made up our Dissident.
Bash ring: Race Face DH/FR
- CNC profiled for 25% weight savings
Bottom Bracket: Truvativ Howitzer for 51mm chainline
- CNC-Machined Alloy L & R Cups in Tech Silver
- 2 x Sealed Oversized Cartridge Bearings
- Super Strong Howitzer CrMo Spindle
Cassette: Shimano Tiagra 12-25t
Chain: Shimano CN-HG53 Deore
Chainguide: Race Face Diabolus
- 6061 Aluminum boomerang
- Aggressive profiling on boomerang is designed to accommodate flush mounted suspension designs and works well with low chainstay suspension systems
- Injected molded upper guide encapsulates the chain
- 50 degrees of articulation
- Lower inside guide plate is anchored to the boomerang, ensuring no dirt or debris gets in
- Compatible with 68/73, 83 and 100mm BB shells.
- Includes newly designed Race Face aluminum bashguard.
Chainring Bolts: Race Face
Chainring: Race Face 36t
Crankset: Truvativ Holzfeller Howitzer
Crankset Bolt: Truvativ Holzfeller
Fork: Rock Shox Pike 409 U-Turn
- Travel: 95-140mm
- Spring: Fixed Coil
- Spring Adjust: Travel, Rebound
- Damping: Mission Control
- Damping Adjust: Internal Floodgate, External Rebound, Compression Adjust and Lock
- Lowers: Magnesium, IS Disc and 20mm only
- Crown: Forged 6061 T-6 Aluminum
- Steerer Tube: 4130 Chromoly Steel 1 1/8″
- Upper Tubes: 32mm 7000 Series Aluminum
Frame: 2007 Brodie Dissident (M)
Front Brake: Avid Juicy 5
Front Rotor: Avid 7″
Front Tire: Kenda Nevegal 2.5″ DH
Front Wheel: Joytech 20mm sealed hub, Sun SingleTrack 32H rim
Grips: Velo dual density DH style lock-on w/ end plugs
Handlebar: Truvativ Team Riserbar
- AL-7050-TV
- 31.8mm
- 680mm width
- 25mm rise
Headset: Aheadset - TH-870 - 12MM deep cups
Headset spacer: Generic
Housing: SIS
Pedals: Brodie Team
- Replaceable pedal pins
- CrMo spindle
- Sealed bearing
Rear Brake: Avid Juicy 5
Rear Derailleur: Shimano M-761 XT with GS Short Cage
Rear Rotor: Avid 7″
Rear Shifter: Shimano LX
Rear Tire: Kenda Nevegal 2.5″ DH
Rear Wheel: Joytech 10mm Thru-Axle w/ 4 Sealed bearings hub, Sun SingleTrack rim
Rotor Bolts: Standard
Seat: WTB Pure V Race - FR
Seatpost: Brodie
Seatpost Collar: Brodie QR
Shift Cable: Standard
Shock: Rock Shox Pearl 3.1
- Spring: Air Positive with IsoLite Cushion
- Spring Adjust: Air Pressure Via Schrader Air Valve
- Shaft Material: 7075 Aluminum
- Shaft Diameter: 12mm
- Body Material: Forged 6061 Aluminum
- Body Diameter: 29mm
Stem: Truvativ Team
Tubes: DH version from Maxxis and Kenda
