2007 Banshee Chaparral
The Parts:
To know a bike, you have to know the parts on it. Listed below are the parts that made up our Chaparral.
Bash ring: Truvativ
- High Impact PC Guard
Bottom Bracket: Truvativ Howitzer Team
- CNC-Machined Alloy L & R Cups in Tech Silver
- 2 x Sealed Oversized Cartridge Bearings
- Super Strong Howitzer CrMo Spindle
Cassette: Sram PG 950 11-34
Chain: Sram PC 971
Chainring Bolts: Truvativ
Chainrings: 22t and 32t
Crankset: Truvativ Hussefelt 2.2RG
- AL-6066 Forged Alloy arms
Crankset Bolt: Truvativ Holtzfeller
Fork: Rock Shox Totem Coil
- Travel: 180mm
- Spring: Fixed Coil
- Spring Adjust: Preload
- Damping: Mission Control
- Damping Adjust: External Low Speed Compression, High Speed Compression, Rebound and Floodgate Switch, Internal Floodgate
- Lowers: Magnesium, Post Disc Mount (203 min rotor) and 20mm Maxle only
- Crown: Forged AL 66-TV Aluminum
- Steerer Tube: Aluminum 1 1/8″
- Upper Tubes: 40mm Taper Wall 7000 Series Aluminum
Frame: Banshee Chaparral (M)
Front Brake: Hayes HFX 9
Front Cable: Jagwire
Front Derailleur: Sram X.7
Front Rotor: Hayes V8
Front Shifter: Sram X.7
Front Tire: Kenda Nevegal 2.5″ Wire
Front Wheel: Novatech 20mm hub, Sun S-Type rim
Grips: WTB
Handlebar: Truvativ Hussefelt 31.8
- Triple Butted AL -66
Headset: FSA DH Pig
Headset spacer: Generic
Housing: Standard
Pedals: Truvativ Holzfeller
- Replaceable Pedal Spikes via Allen Key Wrench
- Oversized H / T CrMo Spindle
- Oversized Cartridge Bearings for Increased Bearing Strength
Rear Adapter: Hayes 8″
Rear Brake: Hayes HFX 9
Rear Derailleur: Sram X.7
Rear Rotor: Hayes V8
Rear Shifter: Sram X.7
Rear Tire: Kenda Nevegal 2.5″
Rear Wheel: Shimano rear deore hub, Sun S-Type rim
Rotor Bolts: Standard
Seat: Banshee
Seatpost: Titec Scoper telescoping
Seatpost Collar: Generic
Shift Cable: Standard
Shock: Fox DHX 5.0 Air
- Adjustable bottom-out resistance, propedal, air spring pressure, and rebound
Stem: Truvativ Hussefelt
- 4 Bolt H-bar Clamp Design
- 2 Bolt Steerer Tube Clamp
- Bored out for Weight Reduction
Tubes: DH
