2007 Banshee Chaparral
History:
As mentioned on the previous page the best way to describe the Chaparral is that it is a smaller version of the classic Scream. It’s not a hucking bike but still handles hucking to some extent. The 2007 Chaparral comes in a variety of build options to meet your riding style. Our setup came with a dual ring setup, Sram X.7 Drivetrain, and other mid/high grade parts.
The first Chaparral came out in 2003 but it has undergone a few changes for the 2006 model year. The 2007 model has the same frame as the 2006 Chaparral but with upgraded components. The Chaparral features lots of CNC machining and is reinforced in all the key areas such as the shock mount, swing arms, head tube, and bottom bracket area.
I asked Banshee what their mindset was in how they create their bikes and this is what Jason MacNeil said:
Banshee’s “Morphing” design approach
“When designing a frame to “Morph”, we look first at the intended use. The tubing materials and thicknesses are chosen for the correct weight and strength for its intended use. Then, we design custom tubes to optimize the strength and stiffness and to minimize the weight.
Next, the ideal geometry is selected for the intended use. This includes: fork length, head angle, top tube length, seat angle, bb height, and chain stay length. Of course there are many conflicting ideas in regard to what the “perfect” geometry for a certain type of bike is but with over 25 years riding, racing and designing high performance bikes we have developed some certain formulae for frame geometries.
Instead of saying that we want a certain head angle, we look at the steering trail because this more accurately describes how a bike will react to steering input. We then choose a head angle that achieves this trail with the length of fork we wish to use.
Top tube length and seat tube angle work together to influence rider comfort, confidence and the rider’s ability to generate power. Therefore different riding disciplines will require different top tube lengths and seat tube angles. Instead of using BB height in my design, we try to make the “drop” of the frame match the fork travel and ground clearance requirements.
Chain stay length affects the natural turning radius of the bike and works in conjunction with the trail. Chain stay length is kind of like choosing skis - shorter slalom type skis and shorter chain stays are best for quick turns and nimble handling conversely longer giant slalom type skis and longer chain stays are better for higher speeds and longer carving turns.”
