2007 Avid Code
In the field:
The Avid Codes are some very impressive brakes. They’ll make you reconsider if you need to swap 8†rotor’s for 7â€, or even 6†ones. If you demand a lot of your brakes, are tired of arm pump, desire brakes that stop on command, and don’t care about weight then these brakes might be what you seek. If you’re a heaver guy or desire more power, the optional metallic pads offer a significant increase in braking power should the stock organic pads seem lacking.
The Code’s work amazingly well and if you get a chance to try them out, do so. The brakes stop you immediately and offer some nice modulation. The codes deliver stopping power unlike any other Avid brake I’ve ever used. They don’t have quite as much modulation as my older Shimano XT 4 pot disc brakes, but they definitely feel like they have more immediate power.
During my testing, I didn’t have any issues with the Codes. There was no brake dragging and in the wet, the brakes had a small hint of squeal but it was pretty insignificant. The brakes stopped me without any hint of studder, fade, or hesitancy. The Codes allowed me to brake later, harder, and with more confidence.
If you’re a Clydesdale, or want even more power (crazyness), you can equip the Codes with Metallic pads. On my downhill bike, I’ll be running the codes with one metallic pad and one organic pad for the best of both worlds.
For 2007, the codes have raised the bar on what a DH/FR brake should be. These brakes are built to withstand downhill and freeride day in and out. Once you try these out (or read further on), you’ll question how they hit on so many major key issues that conventional disc brakes come up short on. The features outlined will help you understand what the Code is, and what they can do for you.
