2006 Morewood Ndiza ST
Geometry and Build Specs:
We’ve upgraded our geometry illustrations with real number’s put into Linkage Bike Suspension Simulation.
Real data. Real numbers entered. Real results easy for you to see.
- Visually see the axle path movement
- View geometry changes as the suspension moves through its travel
- See pedal kickback in relation to the suspension movement
- + lots more
Click the picture below to see the Ndiza in Linkage Bike Suspension Simulation. (flash required)
Manufacturer Data
Geometry Table
| Small | Large | |
| Seat Tube | 400mm | 400mm |
| Top Tube | 560mm | 585mm |
| Head Tube Angle | 67 | 67 |
| Seat Tube Angle | 70 | 70 |
| Chainstay Length | 423mm | 423mm |
| Bottom Bracket Height | 325mm | 325mm |
| a |
Build Specs:
- Bottom Bracket Shell: 73mm
- Head tube: 1 1/8″ x 120mm
- Rear Wheel Spacing: 135mm
- Recommended Fork Travel: 100mm-145mm
- Seat tube: 28.6mm
- Travel: 115mm/4.5″
