2013 Zerode G2 Updates
Zerode has done some major updates to its first generation gearbox bike. Zerode sent along some additional information today on the G2. The changes they’ve done are listed inside.
This new Zerode G2 you see here will be available in the coming months so be sure to get in line if you’re interested.
Zerode G2 - Black Anodized
With two seasons under our belt and a new manufacturer on board we have been able to make a bunch of refinements to the Zerode DH frame for 2013. Designated the Zerode G2, here are some of the changes from the old G1:
1) The geometry has had an overhaul for the G2. 3 sizes (Small, Medium, Large), shorter head tubes, longer top tubes and slacker head angles mean a race ready chassis for all body shapes and sizes.
2) With lessons learned from the G1 we have shaved over 300grams off the frame. Some of this is unsprung weight in the chain stay, axle and rocker further improving the Zerode suspension performance.
3) The down tube yolk has been redesigned to increase the ground clearance by 20mm, increase chain ring clearance for a better primary chain line and incorporates a sturdy shock guard mount so your shock and frame are protected from stray rocks.
More clearance in the revised yolk
4) Each Zerode will come with 2 shifters. The standard Alfine unit and a modified SRAM unit. You choose which one you feel most at home with.
5) A new rectangular down tube is stiffer, lighter and stronger than the old round tube.
6) The chainstay has been redesigned to increase tire, crank and chain tensioner clearance.
7) Reduced travel from 9.25” to 8.3”. With less unsprung weight and an efficient axle path we felt a little less travel would give a more lively feel, reduce weight and make a great pedalling chassis even better without sacrificing it’s superb bump eating ability.
8) New colours….The G2 is Bead blasted and anodized in Black or Charcoal with four decal options. Custom Anodizing is available.
Ano Black Zerode G2 Option
Cane Creek Double Barrel suggested setup
Zerodeusa.com or zerodebikes.com
Related Articles:
TAGS: ,
