2013 Formula Disc Brakes – R1, RO, T1, RX – Forks 33 and 35 29er model
Formula is celebrating their 25th anniversary this year and they’ve got a variety of new things they’ve added to their parts lineup this year as well as some changes to their caliper piston to improve pad rollback, pad retraction and rubbing across the lineup.  They’ve added some new wheel options as well as fork models as well. Check it out inside.
Across the range of Formula brakes for 2013, the ECT (Enhanced Caliper Technology) has been implemented to improve performance, pad rollback, and more rotor clearance.  They’ve almost doubled it from previous years (see below shot).  A new O-ring is also used inside as well.
updated ECT caliper across the range
Updated ECT caliper
When it comes to brakes, Formula’s offerings are some of the lightest out there. Formula offers a Titanium upgrade kit across their brakes as well should you want the best of the best.
New brakepad
Formula also has some new pads also this year that utilizes a modified compound from new compound.  Notice the new back plate that allows for better contact with the entire piston.
Formual's RO featuring oval pistons
The RO remains at the top of the food chain for gravity enthused riders in the Forumla lineup and all of the same benefits from 2012 carry over still.  The main seperator in the Oval brakes is that they use oval pistons in this brake to keep the power up and cooling down.  Check out the video we shot to learn more about the RO and speed lock option last year, but keep in mind they’ve added ECT as well this year to the Oval making it even better.
Forged “semi” radial master cylinder
• High capacity reservoir
• Removable handlebar clamp
• Flip-flop master cylinder
• Forged lever blade with integrated TFRA (Tool Free Reach Adjust)
• Hard anodized master cylinder piston
• Laser etched logos
• Forged one-piece post mount caliper
• Unique Oval Piston Technology
• Top and bottom venting caliper body for maximum cooling and performance
• Top loading pads simplify pad changes
• ECT: Enhanced Caliper Technology
– Increased pad roll back (simplifying installation)
– Increased fluid capacity
The T1 replaces The One for 2013. The brake remains much the same as last year however the T1 also gets the ECT caliper upgrade as well as a migration of the hose mount to the inside of the caliper.  The T1 is aimed to be a brake that can work in most every situation.
T1
house gets re positioned to the inside
Forged radial master cylinder
• High capacity fluid reservoir
• Redesigned caliper body with improved hose routing
• Forged one-piece post mount caliper body with 24 mm pistons
• Top and bottom vented caliper body for maximum cooling and performance
To celebrate their 25th anniversary, Formula has created some limited T1 brakes in a special finish.
25th anniversary
Formula 25th
If you’re more into the lightweight All Mountain /Enduro / XC/Trail setup, Formula still makes the R1 and an R1 Racing setup that includes carbon lever blades, titanium hardware, and kevlar hosing in a super lightweight 264g setup.
R1
R1 Racing
In addition to the brake revisions, Formula was showing off their 33 and 35 fork models.
Formula 33
The 33 is intended for XC duty and is available in a QR or 15mm axle option. Travel is adjustable internally and additional details include
• 33mm hard anodized 7000 aluminum stanchions
• Magnesium lowers w/ PM6 brake mount
• FORMULA control closed cartridge damping
7 adjustments + 2 lockout settings
Black or White color option
• FORMULA rebound – 18 adjustments
• Air spring w/ Dual Coil Technology
• HPV (high-pressure valve):
blow off valve prevents damage when fork is locked out
• Polymeric bushings offer low weight and less friction
• Lock Out: crown mounted or remote
• ILS (Integrated Locking System): tool free 15QR axles
• Travel: 26” 85-120mm
Compression damping / lockout
Formula 35 - 29er fork
The 35 Series Formula fork takes things a bit further. Available only in a tapered steerer tube the 35mm stanchion fork offers a more robust offering and additional strength for the 29 inch rider.
You can see additional shots of the 2013 Formula products in the gallery.  Be sure to check out more of our Eurobike 2012 coverage.
Related Articles:
TAGS: ,
