2012 SRAM XO DH 10-Speed Drivetrain Released
Meet the latest addition to the versatile 2012 XO family, featuring SRAM’s first carbon downhill race crank and DH-specific derailleur. The rear derailleur is designed to provide fast and precise shifts for the close ratio cassettes used on DH race bikes, 4X and jump bikes. The 2012 X0 DH drivetrain provides a new level of crank stiffness and shifting reliability for the most aggressive terrain. The sub-800g carbon crank has been developed and proven by top World Cup pros in the most extreme conditions imaginable.
To be the best. It’s why you ride. It’s why we build components. The perfect combination of precision and brute force. No obstacles stopping us. No limitations slowing us down. Ours is a relentless pursuit: To make the climb shorter, the trail smoother, the turn tighter, the descent faster. To give you the strongest, lightest, quickest bike on earth. To be the best.
2012 SRAM X0 10-Speed DH Rear Derailleur
  • SRAM Exact Actuation for precise and dependable 10-speed performance
  • Designed to work with any cassette up to 28-tooth large cog
  • Exceptional shifting performance
  • Lightweight, durable, and reliable
  • Compatible with any 10-speed Exact Actuation shifter.
  • 2 graphic colors: New Silver and Red
2012 Truvativ X0 10-Speed DH Crank
  • The world’s first Carbon DH crank weighs just 750g (claimed), including Bottom Bracket (GXP83, 165mm, 36 ring)
  • Lightest single ring available is made of 7075 CNC alloy, 34, 36, or 38 teeth
  • Available in 170 and 165mm arm lengths
  • All new DH30 spindle for 83mm Press Fit 30 shells
  • Available in GXP, Press Fit GXP, 73 and 83mm spindles
  • Lightest-in-class composite construction with forged aluminum spider and high strength 7075 T6 alloy pedal lug
2012 TRUVATIV X0 CHAIN GUIDE Built by MRP
  • MRP replaceable Skid Plate Design. Truss design adds strength while reducing weight
  • Upper and lower guide including sealed bearing pulley provide full chain retention
  • Easy Installation. Front-access, single-bolt positioning of upper and lower guide with captive hardware
  • Lightweight aluminum mounting plate
  • Low profile installation compatible with wide range of chain lines
  • Available in BB-Mount, ISCG or ISCG 05 mounting standards
  • Two Sizes: 36-40 Tooth Capacity and 32-36 Tooth Capacity
  • Available in black or white
2012 SRAM X0 10-Speed Trigger Shifter
  • SRAM’s Exact Actuation for precise and dependable 10-speed performance 116g (claimed)– super lightweight
  • Impulse Technology
  • Precise rider fit with the first patented multi-adjustable trigger shifter
  • MatchMaker and MatchMaker X compatible
  • 3 graphic colors available: New Silver, Black, Red
2012 Avid X0 Brakes
  • TaperBore Technology
  • Detented; tool free Contact Adjustment
  • Reach and banjo Adjust
  • MatchMaker X compatible
  • Forged aluminum caliper
  • Forged aluminum lever body
  • New carbon lever blades
2012 Truvativ Giga X Pipe (GXP) Team Bottom Bracket
(click to enalrge)
  • Gutter Seal Technology drastically improves sealing against the elements
  • Friction free design and reduced seal drag
  • Custom steel bearings. Tungsten finish
  • Low profile shape
2012 SRAM PG-1070 Cassette
  • The PowerGlide™ 1070 cassette offers an innovative approach to 10 speed cassette design.
  • Optimized by tooth profile and shift ramp design for quick and positive index shifting.
  • The cassette shifts efficiently and positively in all high performance situations.
  • Our new cogset features a semi-spidered construction for a maximum stiffness to weight ratio and is available in seven optimized configurations to best
MSRP
  • Carbon XO DH crank – $444 GXP and $448 BB30 With Ring. Without BB
  • BB GXP 68/73/83mm is $40
  • BB PF30 $52
Product Specs
