Verified Weights: 2011 Shimano M980 XTR
One of the bigger sections we’ve developed of our site is the weights section. We’ve just uploaded most all of the 2011 Shimano XTR M980 components to this section. Verified on our accurate scale, you can see what the 2011 Shimano XTR M980 parts weigh in at!
See how they compare to lots of other components in our weights section. Be sure to check other weights and the most recently added list, as we get them uploaded quite often at
XTR FC-M980 bottom bracket w/sleeve 89g
XTR FC-M980 175mm crank arms 526.6g
XTR FC-M980 42t chainring 83.1g
XTR FC-M980 32t chainring 42.8g
XTR FC-M980 24t chainring 25g
XTR FC-M980 granny ring bolts 5.1g
XTR FC-M980 big/middle ring bolts 7.7g
XTR FD-M981 Front Der 34.9 145.1g
XTR RD-M980-SGS Rear Long Cage Derailleur 176.4g
PD-M980 XC Pedals 307.1g
PD-M985 Trail Pedals 375.1g
CS-M980 11-36t 10spd cassette 272.2g
M988 Trail Brake Rear w/resin pads 248.8g
M988 Trail Brake Front w/resin pads 233.3g
Ice-Tech Metallic Pads 29g
SM-RT98S Ice-Tech 160mm Centerlock Rotor 113.6g
SM-RT98M Ice-Tech 180mm Centerlock Rotor 122.8g
SL-M980 Front Shifter 98.1g
SL-M980 10spd Rear Shifter 103g
WH-M988 Rear QR Wheel 913.7g
M980 XTR QR Rear 64.6g
WH-M988-F15 Front 15mm Wheel 770.9g
