2010 Deity Components
Eric from Deity Components showed us their new products for 2010/2011. Deity has focused on revamping their entire lineup.  They’ve created lighter parts with a clean aesthetic through the use of anodizing and other technology. They have components for downhillers and dirt jumpers alike. Check inside to see all their new products.
Decoy LT Pedal
Decoy LT pedal (click to enlarge)
  • Lightweight concave magnesium body
  • Thin 17mm profile
  • DU bushing and double micro sealed bearing axle
  • Machined red anodized aluminum pins
  • Proprietary forging design for Deity only
  • Claimed weight: 357g
  • MSRP: $100
thin concave design (click to enlarge)
Decoy 2 Pedal
Decoy 2 pedal (click to enlarge)
  • This is their revamped Decoy 1 pedal.  They wanted something different from the other pedals on the market so they went back to the drawing board and have came up with this design
  • Machined 6061 T6 aluminum concave body
  • Thin 17mm profile
  • Cromo pins
  • Proprietary machine design for Deity only
  • Claimed weight: 425g
  • MSRP: $75
Fantom DM Stem
Fantom DM stem (click to enlarge)
48mm or 55mm reach (click to enlarge)
  • Machined from 7075 T6 Aluminum
  • Boxxer standard mount design
  • 4 piece design
  • Adjustable reach at 48mm or 55mm
  • Colors: Black, White, Red
  • Claimed Weight: 159g
  • MSRP: $90
red anodized version (click to enlarge)
Topsoil Handlebar
Topsoil handlebar (click to enlarge)
  • Double butted 7075 T6 aluminum
  • 735mm (29in) length
  • 50mm rise
  • 9 degree backsweep with 5 degrees of upsweep
  • 31.8mm clamping diameter
  • Colors: Black or White
  • Claimed Weight: 283g
  • MSRP: $68
Blacklabel Handlebar
Blacklable handlebar (click to enlarge)
  • 787mm (31in) length
  • 15mm rise
  • Two tone black finish (anodized)
  • Claimed Weight: 295g
  • MSRP: $72
matte and glossy black two tone detail (click to enlarge)
Dirty30 Handlebar
Dirty30 handlebar (click to enlarge)
  • Lighter weight for 2010
  • 760mm (30in) length
  • 25mm rise
  • Colors: Red, Black, White
  • Claimed Weight: 289g
  • MSRP: $68
Vendetta 3.0
Vendetta crank arms (click to enlarge)
  • Redesigned from the ground up
  • 48T splined system
  • Reinforced spline boss on the front
  • Double butted Cromo arms
  • 3D laser cutting process at all welds
  • Lengths: 165mm, 170mm, 175mm
  • Colors: Light blue, White, Black
  • Claimed Weight: 629g (with hardware)
  • MSRP: $124
Vendetta External BB
Vendetta external BB (click to enlarge)
  • External BB for 3 piece cranks
  • CNC machined from 6061 T6 aluminum
  • Compatible with 68, 73, and 83mm shells
  • Oversized spanish bearings
  • Comes with spacers for all shells
  • Claimed Weight: 164g
  • MSRP: $45
Vertigo DH Saddle
Vertigo DH saddle (click to enlarge)
  • Designed for DH, FR, and AM
  • Lightweight and thin saddle body
  • 8mm hollow cromo rails
  • Bumpers on tail and nose
  • Colors: Black, Grey, Green, White
  • Claimed weight: 289g
  • MSRP: $43
Emblem DJ Saddle
Emblem DJ saddle (click to enlarge)
  • Designed for DJ and Street
  • Thin profile
  • 8mm hollow low profile cromo rails
  • R-compound cover for grip
  • Weight: 306g
  • MSRP: $38
Vertigo DJ Saddle
Vertigo DJ saddle (click to enlarge)
  • Thin profile
  • Weight: 306g
  • MSRP: $38
Villan 2 and 3 Handlebars
Villan 3 handlebars (click to enlarge)
  • Double butted 2014 t6 aluminum
  • 710mm (28in) length
  • 75mm (3in) or 50mm (2in) rise
  • 25.4mm clamping diameter
  • Colors: Light blue, black, white
  • Claimed Weight: 329g (3in rise) | 318g (2in rise)
  • MSRP: $55
New Cryptkeeper DJ Frame
Deity has been designing and developing their first DJ frame. It is a more dirt jump specific frame. It has a 69 degree headangle with very short 15″ chainstays and a little bit of BB drop. The whole frame has been heat treated which is very rare for MTB dirt jump frames. It uses a spanish BB and has an integrated headtube design. It will be single speed only with disc brakes. They will also have a more street oriented version down the road with even shorter chainstays and 71 degree headangle with no BB drop. They’re still doing some testing on the prototypes but it will be ready to launch on Halloween of this year.
Cryptkeeper (click to enlarge)
Deity has reworked their whole lineup and are excited to get these new products out to you guys. The finish on these new products are quite a bit better and the use of anodzation heavily in the new parts should prove to be a more lasting finish. Their site doesn’t have these latest products just yet, but you can contact them through deitycomponets.com if you have any questions.
