2011 SRAM X7 2×10 10-Speed Group Launch
SRAM X7 2x10 Group
SRAM X7 2x10 Group
SRAM has released information on their new X7 2X10 Group. Check inside to find out all the details on the new components from SRAM.
THE RIGHT GEAR
For the first time SRAM offers the right combination of matching SRAM X7 components. SRAM X7 features 2X10 drivetrain, X-Glide front shifting, Exact Actuation, new PowerGlide cassette ratios, carbon cage rear derailleurs, new S1400 crank offering and Avid Elixir R brakes. SRAM 2X10 is becoming understood by riders of all levels and segments by delivering a full range of usable gears, less weight and faster and smoother shifting. We build on this with choice, and a strong materials mix aimed at mid-level XC to entry level downhillers and freeriders.
X7 10-Speed Rear Derailleur
New technologies, finish and family strategy create a cohesive performance story. X7 intends to deliver the highest value MTB components in its class. We’ve built in our award winning 10 Speed Exact Actuation shifting technology giving you XX shifting performance at the X7 level. We upgrade our materials story with a 3K carbon pulley cage. We added our new Storm Grey Finish and family graphics package.
Features/Benefits
  • Technology: 1:1® actuation ratio & Direct Route Technology for lighter effort shifting.
  • Resting Position: Top Normal
  • Compatibility: Exact Actuation Ratio, 10 Speed; 36t maximum Speeds 10
  • Weight: 239g (10 speed Carbon Long Cage) *(claimed)
  • Material: Alloy B knuckle, Alloy links, High Strength Grilon® Composite P-Knuckle, Serviceable sealed pulleys, 3K Carbon Cage.
  • B-Knuckle: 6061 Alloy
  • B-Bolt: 7075 Alloy
  • P-Knuckle: Grilon® Composite
  • Inner Link: Steel
  • Outer Link: Alloy
  • Outer Cage: 3K Carbon Fiber / 6061 Alloy Option
  • Inner Cage: Alloy
  • Upper Pulley Bearings: Bushing
  • Lower Pulley Bearings: Bushing
  • Cage Options Available: Long, Medium, and Short
  • Finish: Storm Grey
X7 10-Speed Front Derailleur
The X7 FD was designed from scratch specifically for 2X10. It’s a critical part of our X-Glide shifting experience: the fastest shift ever. It’s new body is slimmer, lighter and good looking. Offered in a wide variety of clamp-mount and direct-mount options.
Features/Benefits
  • Weight: 137g (2X10, Low Clamp) *(claimed)
  • Cage Material: Steel
  • Clamp Material: Forged AL-6061-T6
  • Chainstay Angle: 66-69 degrees
  • Seat Tube Mount: 31.8mm, 34.9mm clamp
  • Max/Min tooth capacity: 15 tooth
  • Cable Routing: Top or bottom
  • Speeds: 2X10
  • Options: High, low clamp and high, low direct mount
X7 10-Speed Trigger Shifters
We’ve added our award winning 10 Speed Exact Actuation shifting technology to the new X7 shifters providing XX shifting performance at the X7 level. The X7 Trigger maintains the legacy of SRAM shifting with new technologies optimized for 2X10. Exact Actuation 10-Speed rear shifters and dedicated 2X10 front shifters. Our new finish and graphics package create a cohesive high performance story.
Features/Benefits
  • Speeds Rear: 10 Speed. Front: 2x (for 10spd FDs only) and 3x(Both 9 and 10 Speed Compatible)
  • Compatibility: SRAM Exact Actuation® Rear Derailleurs; SRAM Double(2x) and Triple Front Derailleurs
  • Gear Indication: No
  • Max Down-shifts: 1
  • Max Up-shifts: 3
  • Technology: Impulse Technology
  • Matchmaker: Yes
  • Release Lever: Composite
  • Pull Lever: Aluminum Die Cast-Bushing
  • Clamp: Removable
  • Inner Wire: Stainless
  • Main Bolt: Steel
  • Barrel Adjuster: Composite
  • Lower Cover: Aluminum
  • Top Cover: Composite
  • Weight: 232g (2X10) *(claimed)
S1400 2X10 Crankset
2X10: Lightning-fast and accurate front shifting, through an all-new, patented, mind-blowing performance technology: X-Glide.
Labeling and finish mesh perfectly with SRAM drivetrain families. S1400 features our OCT Hollow Forged crankarm that are beautiful, strong and light. Our new GXP bottom bracket featuring Gutter Seal technology promises reduced seal drag and increased bearing life.
Features
  • BB: GXP and PFGXP
  • Weight: 871g (2X10, 175mm, w/BB) *(claimed)
  • Chainring Bolt: AL Double Hex Type
  • Chainring Materials: AL-7075
  • Chainring Color: Blast Black
  • Chainring Outer Teeth: 42 or 39
  • Chainring Inner Teeth: 28 or 26
  • Compatible Chain Type: 10 Speed
  • Interface: Giga X Pipe
  • Colors: Storm Grey (STGRY) and Blast Black (BTBLK)
  • BCD: 80mm/120mm
  • Crank Length: 170/175
  • Crank Arm Material: OCT-Hollow Forged
Giga X Pipe (GXP) Bottom Bracket
Gutter drastically improves sealing against the elements while reducing seal drag. We’ve designed a fresh new cup forging for a new high-end look. A new standard in external bearing performance.
While other systems rely on side loading the bearings to eliminate play, which causes premature bearing wear, the GXP system is different. The GXP system captures the left side bearing between the spindle and the left crankarm while allowing the drive-side bearing to float axially on the spindle, thereby eliminating the necessity to side-load bearings during adjustment. The simplicity of installation is refined: once it is tightened to the proper specifications you are ready to roll with a worry free BB. The GXP system uses two bicycle specific cartridge bearings and eight seals for a smooth and long lasting ride.
  • Ceramic – Ceramic bearings. Red Ano finish
  • Team – Custom steel bearings. Tungsten finish
  • XR – Custom steel bearings. Black finish
Features/Benefits
  • Material: L&R Cups Die-Cast Aluminum
  • Bearings: Two Sealed Cartridge Bearings
  • Tech Feature: Gutter Seal Technology
  • BB Shell: Wide 68mm and 73mm
Elixir R Brakes
Amazing ride quality achieved through our Tapered Bore* and improved pivot location. Less initial power and deep stroke modulation allows the rider to better use and control more powerful brakes. More power through larger caliper pistons.
Features/Benefits
  • Application: XC/Trail/AM/DH
  • Weight: 375g (Front; Post Mount; 160mm) Carbon Blade is 10g lighter *(claimed)
  • Color: Silver Body / Tungsten Grey or Carbon Lever / Silver Caliper
  • Fluid: DOT 5.1
  • Rotor Size: 160/185/203 G3 Clean Sweep
  • Caliper: 2 Piece; Top Loading Pads
  • System: 2 Piston; Open System
  • Pads: Sintered
  • Additional Features: Tools Free Reach Adjust
PG-1050 Cassette
The new PowerGlide™ 1050 cassette performance is optimized by material choice, tooth profile and shift ramp design for quick and positive index shifting. Our new cassette features a semi-spidered construction for a maximum stiffness to weight ratio and is available in many optimized configurations to best match a wide variety of uses.
Features/Benefits
  • Technology: Power Glide
  • Cassette options: 11-32, 12-36
  • Recommended Chain: PC-1090R, PC-1090, PC-1070, PC-1050, PC-1030
  • Spider Type: Alloy
  • Lock Ring Material: Steel
  • Lock Ring Finish: Pad printed finish
  • Sprocket Materia:l Heat treated steel
  • Sprocket: Finish Blast Silver
  • Weight: 302g (11-32) *(claimed)
X7 Hub set
The smoothness of cartridge bearings at X7 level
Features/Benefits
  • Weight: Front 180g / Rear 425g *(claimed)
  • Hub Shell: Aluminum – Hi/Lo design – Machined windows on rotor side flange
  • Spoke Holes: 32 holes
  • Spoke Hole Circle: Drive side Ø 45mm / Rotor side Ø 58mm
  • Rotor Compatibility: International Standard – 6 bolts
  • Driver Mechanism: External mechanism – 3 pawls
  • Freehub Body Material: Steel
  • Axle type: Quick Release
  • Axle Material: Steel
  • Axle Diameter: Front 9mm / Rear 10mm
  • Axle length: Front 108mm / Rear 145mm
  • Over Locknut: Steel – Chrome plated
  • Bearings: Cartridge bearings
  • Upgrade: Over 506: cartridge bearings
  • Finish / Graphics: Black ano – adhesive stickers
PowerChain 1051
  • Compatible Gears: 10
  • Rivet Type: Solid Pins
  • Closing Link: PowerLock tool-less connecting link
  • Outer Plate Color: Nickel Silver
  • Inner Plate Color: Nickel Silver
  • Pin Treatment: Chrome Hardened Pins
  • Weight: 277 Grams (114 links) *(claimed)
For more SRAM 2X10 information visit Sram2x10.com
[SRAM X7 2X10 Gallery]
