Build: 2010 Intense Cycles 951 FRO
11/23/2009 : sicklines
, Build: 2010 Intense Cycles 951 FRO
Intense 951
Earlier this year we did a preview on the latest Intense 951 frame. Inside we take you through the complete build.
The 951 is Intense’s newest downhill offering. Gone is the Socom for 2010, but the 951 easily can fill its shoes and then some.  Competitive Cyclist set up our 951 frame and made sure everything was good to go right out of the box.  All the pivot bolts were loctited and the bottom bracket, seatube, and headtube were all checked over and chased/faced if necessary. The alignment was also checked.  They include a check list of everything they double checked as well!  Top notch service for every one of their customers without any additional charges.
The 951 features G3 dropouts (which lets you adjust the geometry between three dropout positions).  In the shortest chainstay setting, we noticed that there is not much clearance for a 2.5″ Maxxis tire.  Our Minion DHF comes very close in this position to the top brace.  If you’ve got a bigger tire (or are running a spike) the shortest setting might not be usable depending on your setup.  The other two dropout settings really help open the bike up to be quite different and its nice to see all this adjustability as all courses are not the same.
The 951 has a standard 1.5″ headtube. In addition to a traditional zero stack headset, we also used a K9 ARC headset in the 951 which is an offset headset. The K9 ARC offset headset can be used to slacken (or steepen) the bike’s head angle. In the middle dropout position with the K9 cups, the geometry yielded a 63º HA, 13 3/4″ BB, ~47 7/8″ wheelbase.  With a traditional zero stack headset the geometry in the middle dropout position is 64.5º HA, 14 1/8″ BB, and a 47″ wheelbase.
K9 reducer cups (click to enlarge)
For suspension up front we opted to use a 2010 Rock Shox Boxxer World Cup. The fork matched up well with the frame and the new adjustments on the fork as well as additional chassis stiffness over the previous Boxxer was great. The fork has a lot of adjustability (air pressure, bottom out adjustment, beginning stroke rebound, ending stroke rebound, low speed compression, and high speed compression) and can take some time to get all the settings just right. The air chassis allowed for easy spring rate tuning and fine adjustments that a typical steel spring setup can’t do as easily. The fork is really lightweight out of the box. Overall the fork performed well after some maintenance and tweaking (replaced rebound cartridge and overhauled). Paint on the white fork could’ve been a bit better as well, it quickly becomes scuffed and worn.
2010 Rock Shox Boxxer World Cup (click to enlarge)
To handle the rear suspension we installed a Cane Creek Double Barrel. The shock performs really well with the frame after getting the shock settings lined up. There are a lot of adjustments with the CCDB as well so setting it up can take some time (LSC, HSC, LSR, HSR) but Cane Creek gave us some good starting points. The new changes done to the Double Barrel have been a treat as it has quite a few things done to it. The new hardware (Norglide bushings and new shock hardware) in the CCDB worked great. It has a slop free feel and is quiet.
Cane Creek Double Barrel (click to enlarge)
The black protective sleeve on the shock we’ve noticed can be a bit annoying in dusty situations as the spring can rub on this and make some annoying noises at times.
In the 8″ setting, initially we used a 550lb spring on the CCDB as recommended (for an 180lb rider) and it worked fine but wasn’t quite as supple as it could’ve been. After some use we ended up with a 500lb spring on the CCDB and that allowed it to progress into the travel a little bit easier. The 951 is a pretty progressive bike and it ramps up quite a bit compared to the M6.
For the stem we installed a 42mm Sunline direct mount stem to the bike to try out as well as a Persist 50mm direct mount stem.
cockpit (click to enlarge)
For the handlebar, we used one of Race Face’s new Atlas FR bars that are quite wide out of the box at 785mm and in a half inch rise. We cut it down a little bit to suit our tastes. It comes in a wide variety of colors too, so be sure to check out the wide color spectrum they offer if you’re in the market for a new handlebar.
For the grips we used some Sunline Half Waffle grips. They feel great and offer a good amount of cushion and thickness. They can wear out a bit fast in our experience but we like them just the same.
Sunline Half Waffle grips and Saint brakes (click to enlarge)
For shifting duties we opted to run a XTR rear shifter as well as a custom short cage XTR rear derailleur. Both worked great and the derailleur tucks in quite nicely behind the dropout staying protected.
Custom Shimano XTR rear derailleur
For brakes, we used the new Saint M810 levers and used a m810 4 piston caliper up front and a two piston m800 in the rear. Tons of power and good modulation when needed.
Saint M810 front brake (click to enlarge)
For the seat post we opted to use a Thomson Masterpiece seatpost. Thomson makes one of the best seat posts around and they’re our go-to seat post it seems. For the saddle we used a WTB Silverado. It has a good amount of cushion to it, has a nice slender feel, doesn’t hurt your thighs when you need to grip it, and overall it worked well for us.
Thomson Masterpiece seatpost with WTB Silverado saddle (click to enlarge)
For the wheels we opted to use the new Deemax wheelset. These wheels have taken a beating for the most part and keep coming back for more. They’ve lightened them up compared to previous models and for 2010 they have an even racier version called the Deemax Ultimates. The rims we’ve setup tubeless with Maxxis UST DHF’s with relative good success. Mavic knows how to make rims quite well. These Deemax rims are not quite as beefy as previous versions (or the 823) that can potentially cut through tire sidewalls but we suspect these still could be even less beefy. Denting these rims isn’t an easy task and they could stand to be a little bit softer in our experience for a racer. For everyday riding, they hold up quite well and we’ve had no major issues with them. The rear finally has a small ding in it but that was after some pretty good riding throughout the entire summer. The revised rear Deemax freehub has been ticking perfectly (and has more engagement at 48pt than previous versions).
Mavic Deemax wheelset with Maxxis UST DHF tires (click to enlarge)
For the cranks we chose to use some Atlas FR cranks. The tooth blue color matches the Atlas FR bar as well, which gives the bike a little bit of color. The cranks have held up well and installation was fairly easy. The Race Face crank setup is a little bit different than Shimano. The chainline is adjustable which is nice should you need it. The driveside crank arm attaches to the non-driveside crank arm that holds onto the axle. Getting a chain guide setup with these cranks takes a bit more work as you have to snug up the entire system each time since the driveside crank arm bolts to the spindle and isn’t directly connected to the axle.
Race Face Atlas cranks with e*13 SRS+ chainguide (click to enlarge)
For the chain guide we used the new e*thriteen SRS+ in the 32-36t size. It bolted up quite easily along with a 36t e*thirteen guidering. The 951 has some nice robust ISCG-05 tabs that are welded fully around the BB shell that is reminiscent to the M6. The ISCG tabs could be rotated a bit more but the SRS+ bolted up easily to the tabs and is one of the easiest guides to setup nowadays.
For the pedals we bolted up some of the new Point One Racing Podium pedals. They’re lightweight, thin, and have a unique look to them. They sit pretty close to the crank arm and we’ve been quite pleased with them so far. They have a nice feel to them and the axle although visible, isn’t felt by your feet. The hardened pins have proven to be resilient to bending and the body overall has taken a beating and keeps on ticking. The downside of the pins however is that they use an English sized allen tool. Overall these pedals are great and are a nice finishing touch to the bike.
Intense 951 (click to enlarge)
This wraps up our build on the 951. Total build as you see it above – 37.3lbs. Stay tuned to see the review next week!
