Review: Transition TransAM
Transition TransAM
The Transition TransAM is a fun bike that you can build up in a myriad of configurations including geared or single speed. Read more about what we thought about the Transition TransAM inside.
Transition TransAM
That’s a pretty sweet looking ride. Cool that it can be built up as an SS!
What´s the rider´s height? I´m 6´3″ and ride a SPZ P1 All Mountain with almost the same geometry.. but found the 75mm stem way too short for climbing.. so opted for a 100mm Truvativ AKA stem… and the bike is doing great going down too… have you tested different stem lenghts?
A Specialized P1? I had one of those, the fit wasn’t anywhere near the same as this bike (nor its intended purpose). I’m about 6′3, Kevin (Transition) is about the same height as is Brad and they are on a Large w/50-60mm stems last I checked. Depending on what you’re going for though, a 100mm stem could be used for a longer feel on the TransAM. We haven’t strayed too far away from the 70mm stem (have a 50mm stem as well) as that has proven to be a good length to do a wide variety of riding with the TransAM.
That´s funny cause the geometry is really close, except for the higher standover on the P1.
Actually I feel a little limited on really steep drops and bigger jumps, but I had to find something to fit my needs as I use the bike to go to work too…
I have a FR bike too so… that´s not a problem at all… take a look:
http://is.pinkbike.com/photo/3645/pbpic3645827.jpg
http://is.pinkbike.com/photo/3645/pbpic3645815.jpg
This is a Specialized P1
http://www.specialized.com/us/en/bc/SBCBkModel.jsp?spid=45797&eid=4348
You have a Specialized P1 AM, much different!
I said P1 All Mountain in the first post… no problem.
ISCG not ISCG05? 30.0 seatpost Campy IS headset. I liked the rest of the bike though.
pic of the newer style (shows the chainguide tabs) - http://farm4.static.flickr.com/3517/3736011458_228f937b00_o.jpg
