Park Bike Comparison: Intense SlopeStyle SS
Intense SlopeStyle
Short travel full suspension bikes are quite popular amongst park / lift assisted riders for a wide variety of reasons. We’ve decided to build a few up with a static build kit to see how a select group of frames stack up and compare against each other.
The third bike we’ve selected to look at is the Intense SlopeStyle that is readily available now if you can find it in stock! See the details of the build kit and read some details on the SlopeStyle inside in our build article. We’ll be updating the build article with a few other park frames. Can you guess the last bike we’re including?
Like I said…The Banshee Wildcard should be in this comparo. I have one with almost the identical build save the crankset and I am curious to see the outcome.
The issues you mentioned with the SS are very true
I run 2.4 maxxis advantages and clearence is very tight
I also keep getting twigs, leaves, stones, shell casings from trees and all sorts of crap in my lower pivot.
The other issue i would bring to light after having the bike 18months is bearing life or the lack of it. expensive and annoying!
Apart from that, she is a beast!
