Facebook Twitter RSS MPORA
Spotlight: Magura Wotan
Magura Wotan
Magura Wotan
There is a lot of competition in the All Mountain / Enduro fork category these days. With numerous products available from FOX, Rock Shox, Marzocchi, and Magura riders have several options to choose from. Magura’s Wotan is their long travel Enduro and All Mountain fork offering 6″ of  adjustable travel in an exceptionally stiff chassis. To find out more about the Wotan check inside.
The Wotan (pronounced “Voo Taan”) has been on the market for several years now receiving incremental updates to make it a better performing fork. The Wotan uses an air spring system. For 2009 they have a revised their Albert Select system (now Albert Select+) in order to offer improved valving for better damping throughout the complete speed range. We’ve been riding the Wotan on our Iron Horse SSO project bike and have been relatively pleased with its performance so far.
Features:
  • Double Arch Design (DAD) - makes the chassis noticeably stiffer than a traditional single arch design
  • Maxle thru-axle (20mm tool free)
  • Postmount 8″ disc mount - no disc adapter saves weight but some riders may not need a 8″ rotor for their riding style
  • Albert Select+ damping system - adjustable platform compression damping can be turned On or Off by turning the blue knob a quarter turn. When on, the gold knob increases or decreases platform compression to keep the fork from bobbing while pedaling. This allows you to create a stiffer platform with a greater blowoff threshold for less intense trails or open and plush feel for better small bump compiance. In the Off mode it allows for more active damping without the platform. It can be set up optionally with a remote control lever for easy engagement.
  • 36 mm stanchions
  • Cold forged Aluminum 6082 T6 fork crown with integrated cablestops for the RCL remote control
  • All adjuster knobs made of high quality aluminum
  • Flightcontrol Remote System - allows on-the-fly adjustment of the travel from 160mm to 120mm. Simply engage the control and push down on the fork to drop the travel or lift up on the fork to bring it back to full travel. An optional handlebar mounted remote control lever is also provided to control the system should you want a bar mounted adjuster.
air pressure adjust underneath the cap (click to enlarge)
  • Rebound adjust
  • Shock pump and handlebar mount remote control lever included
  • 1 1/8″ steerer tube only
  • 540mm axle to crown (5mm less than a Lyrik)
Weight: 2618g (with Maxle)
Price: MSRP $899
Colors: Black, White, optional colorways available in Europe
If you’d like to find out more about the Magura Wotan or find a dealer near you check their website. Most bike shops like Red Barn Bikes can get them through BTI.
