Spotlight: 2009 Mavic Deemax
2009 Mavic Deemax
Mavic’s Deemax is one of the most visible and recognizable wheelsets in the downhill and freeride market. When it comes to wheelset’s and rim’s, Mavic swings hard bringing a solid product to the table no matter the discipline. The entire Mavic lineup from the 823, 721, 729, Deemax, Crossmax, etc define just how well their products work as these are all highly recommended for durability, lightweight, and performance. The Deemax often sits a top the short list of most riders’ list of wheel choices but the previous version did lack a few things that made it less than perfect. Check inside to see what Mavic has done for 2009 to make the Deemax an even better performing wheelset.
For 2009 Mavic has heavily re-worked the Deemax wheelset to offer riders increased performance and additional features in their venerable wheelset. Lighter weight, faster engagement, and more ride compliance are all welcome improvements to the Deemax. Mavic has also ditched the wild colors and created a more sophisticated looking wheel with some edgy graphics, which many will agree is a very welcome change over past designs.
Features:
- ISM (Inter Spoke Milling) machined rim - The rim wall between each spoke hole is milled it to save weight because these areas are subjected to very little stress. This CNC machining is a Mavic multi-patented exclusive concept (US 6 402 256). The rim is able to perform faster acceleration due to lower rotational weight as well as able to allow for higher compliance offering better control over technical terrain.
- 23mm wide UST tubeless compatible rim means you can easily run these tubeless with the supplied tubeless valve core, or put a regular tube in the wheelset if you prefer. Tubeless compatible doesn’t mean you have to run the wheels with UST tires (Tubeless) but with this wheelset, Mavic gives you the option to easily set it up. The Deemax wheelset works perfectly fine with non UST tires and standard tubes just as well. Converting conventional DH tires to work tubelessly can be done easily on the Deemax’s by just adding some Stans NoTubes and using the supplied tubeless valve core.
tubeless valve core
- The spokes feature a thinner double butted 2.0-1.8 stainless spokes laced in 3 cross pattern. It helps improve overall wheel compliance and gives the wheel a bit of forgiveness over harsh obstacles
- Features an ITS-4 alloy freewheel body for lighter weight. The axle system was also revised as well and holds the freehub securely to the body as well as offering some optional axle configurations for the rear 135mm deemax wheel (Qr, 10mm, 12mm).
- SRS (Spoke Retention System) hub machining to avoid spoke ejection - The slots on the hub body are machined in a special way, to make sure that the spoke head is emprisonned and will not pop out of the hub. The spoke still has a certain travel in the slot, in order to let the wheel absorb some of the terrain obstacles.
- 4 pawl freehub - The system works with 4 pawls, working 2 by 2 in order to provide a fast engagement (48pt). Each pawl is energized by an individual spring, to reduce the risk of failure.
- Front hub 20mm x 110mm only
- Available in 135mm and 150mm x 12mm rear hub. The 135mm version has options to convert between- 12mm thru axle, 10mm thru axle, and QR (with adapters).
- 28 straight pull spokes front and rear for 135mm rear wheelset / 28 straight pull spokes front and 32 straight pull rear for 150mm rear wheelset
| Mavic | Deemax 20mm front wheel |
2009
1038 |
| Mavic | Deemax 12 x 150 rear wheel |
2009
1182 |
Price: MSRP $899 (135mm wheelset) $999 (150mm wheelset)
If you’d like to find out more about Mavic’s Deemax wheelset visit their website. If you’d like to purchase a set of your own you can check Mavic’s website for a local dealer or visit Competitive Cyclist. We’ll be putting the Deemax’s through some testing this summer so stay tuned to see and learn more about the Deemax’s and how they perform.
