Facebook Twitter RSS MPORA
Transition TR450 Prototype Bike
Transition TR450
Transition TR450
The Transition TR450 is designed as a dedicated downhill racing machine. It doesn’t replace the Blindside. Factory rider Lars Sternberg, along with other select riders, will be rallying the frame all season. Transition expects production models to be ready sometime early winter 2009 for the 2010 race season. Check inside for more details.
click to enlarge
click to enlarge
  • 9.5″ x 3″ shock (placed low in the frame for lower center of gravity)
  • 2.75 : 1 leverage ratio
  • 8.25″ of travel
  • Linkage actuated
linkage detail
linkage detail
  • internal cable routing for the rear derailleur
click to enlarge
click to enlarge
  • frame takes an integrated 1 1/8 IS style, orbit IS integrated style up top and 1.5″ lower cup
click to enlarge
click to enlarge
  • ISCG-05 tabs (BB/ISCG tabs are one machined piece)
click to enlarge
click to enlarge
The bike is still in prototype phase so don’t expect it this summer (aiming for late fall 09 / early  2010)
Current prototype geometry
  • Wheelbases right now on it is 45.5 (S), 46.5(M) and 47.5(L)
  • Chainstay length is 17.5″
  • Head angle is 64 degrees
  • 14″ bottom bracket height
  • 31.6mm seat post
  • 83mm BB / 150mm rear
  • Alloy rear axle
There are large cartridge bearings at all pivot locations, with an absolute monster of a bearing used at the main pivot for durability and frame stiffness. All bearings are pressed directly against machined bearing seats inside the linkages, eliminating misalignment that can occur when bearings placed at outer edges are “pinched” together
click to enlarge
click to enlarge
Custom tube shapes were developed and the downtube has a tooled reinforcement rather than a traditional weld on gusset. This thicker section reinforces the underside of the downtube/headtube junction without the stress riser created at the edge of a weld on gusset. The front triangle features double welding, which creates a thick but smooth weld and yields a significant increase in strength for high stress areas.
click to enlarge
click to enlarge
Mud shedding was a key concern in the design of the frame. Excessive pockets were avoided and many parts, like the dropouts and rear triangle yokes, are hollowed from the inside and smooth on the outside so mud won’t collect in hard to reach places.
click to enlarge
click to enlarge
click to enlarge
click to enlarge
Transition was not setting out to create an ultra light fragile pro-only frame; this is intended to be a dependable bike that riders can trust race after race. That being said, the TR450 frame is not an overbuilt tank either. The painted medium prototype frame weighs in at a respectable 11.6 pounds with a DHX RC4 (with steel spring), aluminum rear axle and all frame hardware. Lars’ complete bike weighs in at 39.5 pounds as pictured here. Retail pricing has not been announced, but customers should expect a great value with amazing performance for the price.
click to enlarge
click to enlarge
click to enlarge
click to enlarge
[2010 Transition TR450 Gallery] [Transition Bikes Website]
14 Comments
    Looks like someone likes Treks designs…So, I have to say that is a great looking bike!
  • Looking good… hope to get my hands on one soon :)
  • No mask while spraying those swingarms? Duh!
    • not as huge of a deal with powdercoat but i’d still wear one
    I’d hit that
  • People are going to be dropping there Blindsides like crazy to pick up these bad boys. Evil… eat your heart out.
  • Looks like a Ventana. I like the design and the clean look. Rear suspension seems to work really nice.
    Good job boys!
  • any idea about its weight?
    • It’s still a prototype but it is 11.6lbs with a dhx RC4 and steel coil. The build you see above of Lars’ weighs 39.5lbs
    I like it. Good clean look.
  • that is one of the cleanest looking bikes iv ever seen that thing is all busssiness
    it look like an evil revolt and a rocky mountain flatline
  • omg awesome looking bike, can’t wait to get my hands on one!
  • how much does it cost
