Spotlight: Point One Racing DM Stem (Limited Edition)
Point One Racing Limited Edition DM Stem
Point One Racing has produced some limited edition stems that are a little bit different than their standard stems. See inside for some details on some of the new Point One products.
The limited edition stems comes in a nickel plated finish. They’ve got two limited edition stems (one 50mm direct mount and a standard 50mm stem). Like all their products, they’re machined in the USA with precision equipment.
In addition to the nickel finish, they also come stock with high quality Ti bolts and have some custom etchings to boot.
To match up, Point also has nickel coated time capsules to match. The time capsule gives a cleaner look over standard spacers as well as offering that little bit of extra weight savings as the top cap is integrated with the spacer to give a cleaner finish.
If you needed standard spacers, Point also has you covered there as they make their nano-second spacers in a wide variety of sizes (5mm, 10mm, 20mm, and 30mm). They’re necked spacers (middle is machined down) and are featherweights compared to standard spacers.
Nano Second spacers are necked (click to enlarge)
| Point One | 31.8mm Split Second DM LE |
2009
113 | |
| Point One | Time Capsule 15mm w/bolt |
2009
19 | |
You can see our review of the Point ONE direct mount stem here and the Split Second stem here. If you’d like to find out where you can purchase Point One Racing products or find out more information, check their website - www.pointoneracing.com
woo that’s lite!
Alright now…you must stop posting all these nice toys…I was trying not to buy anything for myself this holiday season, but you are making it EXTREMELY difficult.
so what forks are they available for?
It will fit any crown that has the Boxxer direct mount holes (Boxxer, Fox 40 crown (2009), etc).
wow… lite & nice looking DM… better than the black one… but it looks like sunline now.
So after seeing this feature and determining that a Straightline will not fit, I bit the bullet and ordered a Point One DM Limited Edition.
Holy good god damn Bat Man is is freaking nice in person.
Light, and nicely finished with Ti bolts at 112g
I can’t wait to get it out on the trails after the snow melts here in my area.
Looks and finish appear to be top notch.
nice, it should be pretty sweet on your new rig!
I dont usually comment, but after reading through so much info I had to say thanks
