Facebook Twitter RSS MPORA
Spotlight: Gravity 2009 Products
2009 Gravity products
We got a chance to check out some of Gravity’s 2009 products for next year. We’ve showcased a number of their other products (2008 wheelset, light stem and 800mm handlebar, light crankset).  Interested in seeing what they have to offer for 2009?  Inside we’ve got their Direct Connect Boxxer direct mount stem as well as revised Gravity crankset, some new grips, and DH stem.
2009 Gravity Crankset
Crank arms - The 2009 Gravity crankset features cold-forged, monocoque 6061 / T6 aluminum arms that have chromoly pedal inserts for durability and strength.  They’re stronger than previous Gravity cranks and have a very boss look to them.
The crankset is available with arm lengths of 165mm (shown here), 170mm, and 175mm.
They are offered in a two tone black anodized colorway with 3D forged logo that finishes them off with a clean look.
Bottom Bracket - The bottom bracket offered with the Gravity crankset is their MegaExo Quad external BB that features four cartridge bearings and a 24mm chromoly spindle.
The crankset if available with a 68/73mm or 83mm bottom bracket (show here).
Chainrings / Bash ring - The chainrings are CNC machined 7075 / T6 aluminum.
A 22t/32t chainring set up is included with the crankset as well as a clear polycarbonate outer bash ring to keep them protected.  Should you choose to run these in a single ring configuration, similarly to their Gravity Light cranks, they feature a removable granny ring spacer to allow for better clearance with chainguides.
MSRP - $259.99
2009 Direct Connect Stem
The Direct Connect stem is designed to work on forks using the Boxxer Standard mount.
The stem has an adjustable length of 45mm or 55mm.
It has a rise of 10 degrees.
It features a solid 4 bolt face plate.
Offered in a two-tone anodized colorway to match with Gravity other parts.
MSRP - $59.99
2009 Gravity DH Stem
The Gravity stem features a recessed top cap (included) for a smooth look.
It is forged and CNC’d from 6061 / T6 aluminum.
The stem will be available in 40mm and 55mm lengths for the 1 1/8″ steerer version and 50mm length for the 1.5″ steerer tube version.
Both steerer tube versions offer a 31.8mm clamping diameter and 10 degrees of rise.
Stack height is 46mm.
Two bolt pinch rear and four bolt solid faceplate.
Weight - 306 grams
MSRP - $69.99
2009 Gravity Lock-On Grips
These new lock-on grips from Gravity feature a 140mm length.
They have Kraton rubber and alloy lock rings.  Once tightented down, the allen screws recess nicely into the lock rings.
The grips will be available in light grey, mustard yellow, and black and includes color matched hard rubber end plug. The black color has a harder durometer for durability while the others have a softer compound. The logo-ing on the grips is unique but could use some refined logo alignment for a more esthetic look.  The grips are a fair bit longer than typical mountain bike grips at 140mm and have some nice contour to them for added comfort.   If you’re looking for a longer lock-on grip, this is the answer.
MSRP - $23.99
Part Year Real(g) Pic.
Gravity 83mm Crankset 165mm 22/32/Bash Quad BB  2009 1276
Gravity 83mm Crankarms 165mm 83mm (Arms +pinch bolt) 2009 887
Gravity 22/32/ bash bolts / granny spacer 2009 225
Gravity Quad 83mm Bottom Bracket 2009 164
31.8mm Gravity Direct Connect Stem 45mm / 55mm w/bolts 2009 209
Gravity Lock-On Grips 140mm 2009 125
To check out more Gravity products and find out more information check their website  - www.ridegravity.com
2 Comments
    Maybe I should invest in that neat little boxxer direct mount. It looks pretty sweet and pretty light.
    Ps.: What is the green round thing that comes with the cranks?
  • THe Green round thing is a bottom bracket bearing holder. Basically when you press on the crankset, to make sure you don’t push out the bearing on the non drive side, you hold the green cap on it.
