Obtainium Performance : New Lower Weight Springs
If you’re a lighter weight rider and struggle to find a (200 - 275lb) spring, Obtainium now has you covered.
Obtainium Performance Products (made in the USA) makes some high quality springs for shocks made out of aerospace grade Ti and they’ve now got some new springs in stock including:
200 x 3.0 , 225 x 3.0, 250 x 3.0 , 275 x 3.0 (these will also fit 2.5″ and 2.75″ stroke dampers according to Obtainium)
These are generally very hard to find. Take advantage of it and check out their other high quality aerospace Ti springs that now go up to 650.
Read our writeup on the Obtainium TI Springs here.
I’ll be impressed when they actually start making springs longer than 3″… this BS about a 3″ spring working for a 3″ stroke is nonsense. If you want full performance from your damper, whatever brand it is, you need a spring that is at least 10% longer than the damper’s stroke. Basic suspension principle that applies to all coil-over dampers that, for some reason, Obtainium thinks a cheap little adapter work’s around. Sorry but, if I’m forking over this kind of cash on a spring, I’m not doing “work arounds”…
10% longer? Where did you come up with this figure? The length of the coil isn’t what is crucial, its the distance between the coils.
You could have a spring that is 2x as long as the damper and still have it not work if the distance between the coils isn’t big enough. Nothing wrong with the way they’re doing it. Its simple math, not random % numbers.
650lbs Ti springs…but only in 3″ strokes…Too long
I want one that fits a 2.25 stroke…
