Deity Tibia Seat Post and Choker Clamp
Deity has been hard at work the past year refining and improving their lineup of components. Two of the latest pieces they’ve got this year is their Tibia seat post and their Choker seat clamp. Check out the details on these goods inside.
First up, the Tibia seat post. It comes in one size, 27.2 and uses 7075 shims to accommodate 30.0, 30.9, and 31.6 seat posts. The seat post is a high polished ano with either gray or white deity logoing in a lightweight package.
The seat post is 3D forged out of 2014. The inside of the seatpost as you can see is not your typical run of the mill seatpost and is oval shaped.
The clamp takes up to 8mm railed saddles. The clamp is the same as the Shadow Conspiracy spring loaded clamp but with some deity styling.
The post uses a single bolt to tighten the clamp and is easy to use and adjust. Dialing in the seat angle is pretty easy, but it does have predetermined teeth that the post will go into once you snug it up so the adjustments aren’t limitless on it.
The post comes in a 350mm length, so you can cut it as you see fit. For every 20mm of tubing you cut, ~9g is saved. Maintaining 100mm post insertion into your frame is key when you’re cutting seat posts as well.
The deity Choker is new and clean looking. It’s machined out of 6061 T6 aluminum and is available in 31.8mm or 34.9mm sizes.
The clamp is available in white powdercoat, or black 34.9 ano as shown here.
The clamp features an oversized bolt as well.
The clamp doesn’t have a lip on it like our other typical seat clamps that sets where the clamp will rest. Deity says this is to increase compatibility across various bikes that sometimes have paper thin seat tubes which can sometimes cause interference when inserting a seat post.
MSRP:
Tibia Post – $45.00
Choker clamp – $15.00
| Part | Year | Real(g) | Pic. |
| Deity 34.9mm Choker seat post clamp | 2008 | 36 | ![]() |
| Deity 27.2 x 350mm Tibia seat post | 2008 | 268 | ![]() |
| Deity cut 20mm of Tibia seat post | 2008 | 9 | ![]() |
You can see more weights in our weight section of Sick Lines.
You can purchase most of these goods directly off the deity website or at any good bike shop. The deity parts have come a long way and they keep looking better and better with feedback. Deity stands behind their products and offer great service should you ever have an issue with a defect, or in need of a crash replacement piece at a healthy discount to keep you rockin’. Feel free to let them know what you think about their products. Stay tuned to see more deity product information soon!
